Permanent magnet assisted motor coil designs
Started by captainpecan, January 24, 2022, 02:35:06 AM
captainpecan
Quote from: seychelles on April 10, 2022, 11:49:48 AM
CRITICAL TEST IS ONE NEED TO KNOW WHAT PULSING VOLTAGE
TO GET THE MAGNETIC GENIE AWAKEN .
I've got some information on that one already. If you go back to the earlier pages, I was posting charts of voltage tests on my coils to try and understand the effects of number of turns, current, and voltage to unleash the genie per say.... I increased the voltage .5v at a time and recorded how much flux at a certain distance was changing. I was expecting to hit a spot in the voltage where it would all the sudden flip and show a large change in flux. That on the other hand didn't seem to happen at all. What I found was that it was directly proportional to the power added to the coil. For instance, I did tests with no magnet in the core, and the flux was way less as you may have expected. But on the permanent magnet embedded cores, there never was a certain flip voltage. Every bit of added energy seemed to release a little more inner field. It was not as I expected but I have duplicated it over and over. It's kind of a bonus in a way if someone is trying to make a very low powered device like what I am also doing. You can see benefits right off the bat even at 5v instead of waiting for all the benefits to show up after, say 24V to flip it. No clue of course how that would coincide with your transformer concepts, but it is a clue as to what it is doing anyway.
Just for a quick recap of what I found out. The more turns on the coils the stronger the magnetic field of course. The higher resistance of those extra turns did in fact decrease the current draw, but still increased the overall flux. High current always makes a great magnetic field of course. But what I found was the overall efficiency continued to climb the more turns I added. Even adding the coils in series and taking the measurements. Of course, voltage had to continue increasing to get a good field the more turns and resistance that was added, but I also figured the actual ratio of field change per amount of milliwatt used. And I never hit the point where it was counter productive like I expected. Just had to keep using more voltage to get even more milligause per milliwatt. Very interesting. My tests showed that the added resistance was not really hurting me other than I needed more voltage to flow less current.
seychelles
MAYBE USE FERRITE MAGNET BECAUSE THEY WEAKER. THEN THE GENIE WILL
EASILY POP OUT.
captainpecan
Quote from: seychelles on April 11, 2022, 12:26:35 AM
EASILY POP OUT.
That is actually something I have not tried. I have made my coils so I can still remove the core magnets. I think the local craft store has some 1/2 ferrites for dirt cheap. I think I'll give that a go as well when I can just for the sake of knowing how it will work. Who knows, maybe I'm not even releasing the majority of what lies within yet with my existing testing. Thanks for the thought.
seychelles
captainpecan
Not much new to share yet. Have 2 coils left to wind and it goes back together. It's getting there slowly.
