Permanent magnet assisted motor coil designs
Started by captainpecan, January 24, 2022, 02:35:06 AM
0 Members and 23 Guests are viewing this topic.
seychelles
CAPTAIN THE HIGHER THE FREQUENCY THE HIGHER THE ENERGY .
captainpecan
Quote from: seychelles on April 13, 2022, 06:53:28 AM
CAPTAIN GET OUT OF THIS MOVING MAGNET WAY OF THINKING THINK OF NO MOVING PARTS
TECHNOLOGIES. THE HIGHER THE FREQUENCIES THE MOST ENERGY. REM KILOWATT HOURS.
THINK MICROWAVE AND HIGHER ENERGY GENERATOR.
I see what you are getting at, and I am very much interested in that as well. That's just not where my mind keeps taking me. I feel so many have dug into that side of FE that know WAY MORE than I do, and I still haven't seen anything come through that has been groundbreaking. I spent almost a year trying so many different versions of a TPU and trying everything I could think of. I always ended up with a crappy version of a transformer that didn't even work as well as the off the shelf transformer I can buy for a few bucks. Not that I don't believe in it, just that if I drift down the avenue looking for FE in a way that is not of interest to me, the constant failures that we all get over and over again just wouldn't be fun for me anymore. I took about 9 years away from the search after a lot of burn out and trolls hitting me every times I shared and idea. But deep inside, I still hard that part of me that just wanted to hit the bench and do try something new and see what happens. I love working on solid state ideas and many others, and learning from them. But this magnet in the core concept has been bugging me and I simply need to learn more about it. The solid core version of the same idea goes along with the Flynn Motor concepts and many others that use similar ideas in a solid state version. To my knowledge none have really shown FE yet. This is a twist of all that I can learn from their work, and take it down a slightly different path that I don't think anyone has tried yet. After all, nearly all devices on all of these forums do not produce more out than is put in. Mine is probably just 1 more. But when I'm done with it, I will personally know WHY it doesn't work, and I won't be plagued with those WHAT IF scenarios I never tried. After all, I have replicated quite a few different devices from others work. I finally found one that I have never seen before that follows a concept that is very simple, yet nobody has every laid it out in this manor and tried it. Probably just another way to fail, but then I will know, and the knowledge of knowing exactly why it's not going to work makes it a success to me. I am one of those guys that have been intrigued by magnets since I was a child. I still can sit and play with magnets for hours on end. The invisible force intrigues me. I have a burning will to understand why it works and what is really happening. If I never find free energy, doing these kind of projects, makes me feel like that little kid playing with his magnets and toys again. Sometimes with all the things in life tearing us down, we it's nice to take your mind away for a bit, and play with your toys per say... lol.
captainpecan
Quote from: seychelles on April 13, 2022, 11:41:15 AM
That makes sense actually. I will be following everything people post that helps me understand these things better. I have a nice oscilloscope that didn't get nearly enough use. It's time it stops collecting dust. I will have some extra wire and magnets and stuff and plan to wind a few special coils to try some of your solid state thoughts you've brought up that kind of encompass this whole concept. I will have a few questions I'm sure before I wind some of it. But it will be just a bit before I get there. For sure I will wind up a bifilar coil and try the parallel turns as you suggested and see if I get some boosted flux.
seychelles
IT IS NOT A BIFILAR. BUT TWO INDUCTORS OF THE THE SAME VALUE ONE WITHIN THE OTHER.
I HAVE NEVER TRIED IT BUT IMAGINING THAT IT WILL ENHANCE THE OUTCOME. DUE TO LINE OF
FORCE COMPRESSION. JUST MONKEY THOUGHT. IT HAS TO BE PROVEN. EASILY TESTED . TWO ELECTROMAGNET
ONE WITH THE SAME LENGTH OF WOUNDED WIRE AS PER THE MONKEY DOUBLE COILS AND CHECK THE MAGNETIC PULL USING
A SCALE. SAME CURRENT SAME VOLTAGE.
