Luling magnet motor with 3D printed parts (motion only bij permanent magnets)
Started by knovos, February 18, 2022, 11:02:07 AM
Ufopolitics
PUSH-PULL DIGITAL FORCE SCALE 500 NEWTONS
Link above is from China...it is $49.00...or maybe you will find it cheaper and closer to you.
Believe me, you will need this tool to tune your Motor...for best performance, even if it runs and you are very happy...LOL.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
GETTING YOUR TRIGGER SET.
Here is a graph of what you need at Trigger setup:
1- You need a MUCH SOFTER tension force spring than main Piston Spring as a Return Spring for Trigger.
2- Then You need a Trigger Lever STOP, in  order to avoid Lever to get in the middle of the way of Piston traveling or with REAR yellow Plate.
―Leonardo da Vinci
Ufopolitics
Hello Knovos,
Also...
Your Lower Rear extrusion (where you are planning to set springs) at Yellow Rear Plate...I see it in the way for whole system to work properly. basically at high speed it will definitivelly seeing it crashing.
EDIT 1: I am seeing your piston and whole motor already running!!...as am also seeing all things that need to be corrected...to work wonderfully!!
So, I believe it would be better to just set Two Springs at center like I have shown...all you have to do is print two more yellow plates...or hold springs by bolts on plates.
A Graph to show you...
―Leonardo da Vinci
knovos
Thank you very much for all the suggestions. I think I have all the corrections covered.
Any new advice is welcome. I ordered the meter :D  €38,-
regards,
Knovos
knovos
If the piston needs more weight I can print the model hollow stop half way the print, put a piece of lead in it and finish the print 8)
