0 Members and 81 Guests are viewing this topic.
rakarskiy
I do not need public recognition to understand whether the system works or not. And how, the system closes the technology, very well informed.
Holcomb is the case when the initiator, producer and investor all rolled into one. His system just blew it. Judging by the changes in his patent, not everything is so simple with the system and Holcomb.
Jimboot
Quote from: kolbacict on July 14, 2022, 04:29:05 AM
A coil was wound on top of the stator of a brushless three-phase motor.
The field rotates along the wound wires.  EMF is not induced in this coil at all.
Later, this coil was wrapped on the outside with permalloy tape to close shopt the stator poles.
Nothing changed.   :)
I don't quite understand. How many poles did the stator have?
Thanks.
Ufopolitics
Nothing changed.   :)
@Kolbacict,
Of course there will be no induction at all!!
You have made the perfect example of "horizontal conductors" not being induced at all...You have absolutely zero VERTICAL CONDUCTORS, which are the ones that get induced in ANY GENERATOR.
Use as reference for "vertical" as the conductors running parallel to shaft...you have zero in your outer coil.
I will post your image with the proper winding type you need...later.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
@Kolbacict,
Try this type of winding around your stator...then come back and tell Us...
I believe you have Nine (9) stator tooth in your setup...and it is a 3 phase...so, use the length of Three (3) Coils for your outer coils length, meaning you will get on each outer coil, one phase...but, overlap them...so you have more than just three outer coils...but, maybe twelve or more...
Cheers
Ufopolitics
―Leonardo da Vinci
kolbacict
Quote from: Jimboot on July 14, 2022, 08:14:24 AM
Thanks.
These are motors from CD drives. BLDC three-phase motor.
There are 9 spikes in total, but they are combined in three serial coil.
I assumed that there would be no induction in a horizontal conductor, but it's nice to see it from your own experience. And, besides, the field at is not simple, motionless, as in a transformer, but running.
So I thought, and suddenly will anything!
