0 Members and 27 Guests are viewing this topic.
Feb2006
Quote from: Ufopolitics on July 18, 2022, 08:45:35 AM
Hello Feb,
I think it could be disregarded, thanks to the ferromagnetic core(s) there is always a delay in the Field collapse which is greater than 8ms...
The Field collapse takes more time, and as long as we do not allow the reverse currents to fully develop within coils, it is harmless.
Take care
Ufopolitics
So my two pole LinGen should work with a fast enough PWM signal ?
Let's say 4 ms on 1 ms of or faster.
With my setup I can switch in the microsecond range.
Ufopolitics
Quote from: Feb2006 on July 18, 2022, 12:41:50 PM
@Feb,
So, on these systems, and according to my experience...first thing you should look for is a higher resistance of your exciting coils, based on small gauge wire and more turns per coil...basically if you are working on electronics as drivers...and so, you should manage to have a Full Induction Field which will not consume more than 1.0 to 2.0 Amps at full driving power...however, generates a strong Field (strong EMF)
On your end electronics drive, I highly recommend to use Optocouplers for low signal transfer (to Gates) of your FET's or FET's Bank(s).
I have no idea about your coils arrangement, gauge size, number of turns, etc,etc...and how would you be driving coils to simulate a displacement of the field...so, my advice ends here.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
To All...
Related to Lenz and these Non Rotational Systems...of course Lenz is present, however, not physically, since there is no rotation of any mass that causes induction, but just the Magnetic Field, which is massless, frictionless...So, all you will note is a high pitch/low bass "humming", whenever you load these generators...similar to a High current loaded Transformer.
Lenz will cause Input currents to increase when Non Rotary Generator is loaded, however, this increase are never at the levels that you all can observe in a typical rotary generator.
A typical rotary generator have a huge steel massive rotor core, that when the generator is fully loaded tends to lock itself (physically) with stator (a Full Lenz Effect)...this creates an immediate "skyhigh" increase of currents as RPM's decay...then AVR sends a mechanical signal to ICE, which "fully opens its throat" to more gas...increasing torque to max levels...to overcome Lenz stiffness of this huge and heavy stiff rotor.
On Non Rotational Generator Systems, all we need to do to overcome Lenz, is about the same thing as a typical rotary generator do...increase driving speed of the Magnetic Field (or increase frequency, same thing)...except, we are not driving that huge and massive steel rotor...locked physically with another huge steel mass...the Stator.
As we increase the virtual Field Rotational speed, (since there is no physical delay at all) there is an immediate response on currents coming down at Input, as rising on Output...they are Indirectly Related, meaning, the more you increase speed of Field, the lower the Input Amperage comes down to...as the Higher the Output Amperage rises.
Honestly, I could only compare this so different scenarios...as accelerating an old Diesel War Tank, say an old Russian Tank from WWII...versus accelerating a Tesla S Model...or I could even compare it to accelerating a carbon fiber F-18 full blast through the clouds...
Or maybe flying a UFO...using the antigravity effects at max... :)
Sincerely
Ufopolitics
Edit: I changed "an old Sherman Tank" by a "Russian old Tank from WWII"...since German Tanks drive much better and are far better designed from the engineering point of view...compared to a Russian tank...
―Leonardo da Vinci
onepower
Ufopolitics
QuoteRelated to Lenz and these Non Rotational Systems...of course Lenz is present, however, not physically, since there is no rotation of any mass that causes induction, but just the Magnetic Field, which is massless, frictionless...So, all you will note is a high pitch/low bass "humming", whenever you load these generators...similar to a High current loaded Transformer.
Having seen and tested a working device I would have to disagree on a few points...
Lenz Law is very specific and relates to a changing magnetic field inducing a current thus a secondary magnetic field which opposes the magnetic field which induced it. Like most systems it is based on Faraday's equal and opposite reaction to the original action. In effect this is the problem and the solution...
This is not true of a majority of these FE systems and there is no equal and opposite reaction by design. Think of it this way, if we could encapsulate a magnet in a non-interacting vessel to hide the magnetic field we could move it towards a coil. We would then open and close the vessel inducing the coil and then move it away. In this case there can be no equal and opposite reaction because the coil was not induced on approach or when moving away. In effect it is the non-interaction producing a non-symmetrical action/reaction which produces the gain in work thus energy. Simply put, things do not interact the way they normally do.
Here is another example of a non-symmetrical system I tested. Normally we remove or negate one magnetic polarity (N-S) with an opposite magnetic polarity (S-N). We say one magnetic field negates or cancels the other opposite magnetic field. We consider this as normal playing one magnetic field against another magnetic field. However they are not true opposites as both are magnetic fields, they are the same phenomena. If we wanted a true opposite we would produce a demagnetizing field which results in no magnetism of any polarity.
In effect, it is the fact that Lenz Law is very specific and only relates to a discrete sequence of events which gives us an advantage.
Think of Earnshaw's theorem, it supposes that no magnetic dipoles or electric charges can levitate in a stable system. They always flip or orient themselves to attract each other. However if we spin a magnet it can it can find a stable position and levitate above another magnet. This is possible because the theorem doesn't include a secondary force like spin thus it's important to understand when the rules apply and when they do not. The concept of free energy is really no different and were looking for instances when the rules begin to break down and fail to have application.
Your definitely on the right track you just haven't taken it far enough. However as we know most people who came to understand how all this stuff works were overwhelmed and eventually lost their mind, so there's that. I'm a country boy, I have a bad attitude and like to get my hands dirty. So even if I had a UFO parked in my garage I'm not sure I would think much of it. It's a machine, a cool machine, but if I ever showed anyone they would come unglued and much drama would ensue. It always seems to turn into a complete shit show most real inventors want no part of in my opinion.
AC
Jimboot
Quote from: onepower on July 18, 2022, 04:43:51 PM
Ufopolitics
unless it was a Holcomb one and you have photos, your post is just noise here.
