Ufopolitics
Quote from: onepower on July 18, 2022, 04:43:51 PM
Ufopolitics
Having seen and tested a working device I would have to disagree on a few points...
AC
AC,
I have no idea what working device you have tested...but, related to what I have shown (so far) on this website...I can tell you, you can not establish - on a Non Rotary Generators System, a direct (+Field) to (-Field) kind of Physical action-reaction comparison, like you see in any typical generator, where at least one component rotates...whether Induced or Inductor...like it is explained on any Physics Engineering Book related to typical rotary Generator and Lenz Law relationship.
Here the "Reactive Field" is mounted on a steel stator...same as a typical generator...HOWEVER, the Inducing Field or Exciter generating this Reaction, is just a "Ghost", a Spectrum which can go through any real mass, steel, copper, aluminum...like never has been done before in any "official" type generator.
So, I am very pleased to inform to you, that "flying" through a Lenz Reaction on these Systems does not involves any "Physical Reaction"...except a slight increase on Input Currents...
Yes, we have Lenz, I agree on  that before...but realize that the Reactive Lenz Field is anchored to the Output Stator Core and coils...while the Exciting Field is moving through it as easy as a "breeze" of fresh air...
The only issue here, is that by accelerating too much the speed of the virtual rotating field, you loose too much Input Currents, hence, the Field strength decay too much and so, Induction decreases...however, all we have to do is to keep a correct and compensated operating speed.
And so, like any other generator...in order to build a nice and strong Field, we need quite some voltage and some amperage (eg: a typical single phase, home generator 4kW, -when fully loaded- requires around 170V and 2.0 Amps on the exciting Field Coils)...otherwise the Induction would be weak...so, we have to build this setup, to be able to handle that field strength according to our output demand.
Sincerely
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
magnet1c
He never said, if primary does not see lenz, is it driven by purely reactive power,
(of course + the core and copper losses)
if that is the case, gain should be far more than x5, unless lenz is not completely
invisible to the primary.
https://www.youtube.com/watch?v=Nm1VJ65LcXM
BorisKrabow
Hi  nix85
           Let's look at two simple examples.
          1   A classic device that works according to Lenz's rule. The magnet approaches the coil. The magnetic field in the coil increases and if the electric circuit is closed, then the coil begins to counteract the magnet with the same field as the magnet.
         2    A device that works according to other laws.The magnet approaches the coil. The magnetic field in the coil decreases and if the electrical circuit is closed, then the coil begins to contribute to the movement of the magnet with the opposite pole than the magnet .
               https://overunity.com/15307/lenz-free-generator/msg564776/#msg564776
              it is very simple and has been in the public domain for a long time   :) . I hope in the near future many people will have free energy .
                   Best regards Boris
Jimboot
Got some more realistic numbers for last experiment. I could get close to Serge original numbers in his video if I used a resistive load of 0.1ohm
But I have moved on to smaller scale now and I love what I'm seeing from other builders. Thanks SL for the excellent pdf
Ufopolitics
Quote from: BorisKrabow on July 19, 2022, 02:48:39 AM
Hi  nix85
                   Best regards Boris
Hello Boris,
I looked at your project...
Problem I see here is that an Air Coil (for generating "decent" currents and voltage output) is not exactly a good induction example.
An Air Coil is very susceptible to magnetic changes, so, of course, if you  play with alternating poles using a mid set steel plate, it will do reverse within coil as you have said...and tested.
But have you measured your True Output (V&A), versus all energy spent to obtain the process?
IMHO, the ideal generating setup, requires a steel core at both sides, Inductor and Induced, in order that Exciting Field (Inductor) enters the Induced Coil, magnified by steel, and so it transfers great power out...but Lenz, for sure, will be there...
For a Motor application it could be useful, not for a Generator.
Edit: Let me try to illustrate what happens when you do what you are proposing...
When you approach a North Pole to an Air Coil...an Induction process starts in one direction...and if you swap Poles (or interfere by approaching an opposite pole) before the first process ends, then a reverse process starts, which will cancel or severely weaken your first Induction...
So, eventually, what you are doing is generating your own Lenz effect, before Lenz takes place.
Remember, the higher your power Output, the stronger Lenz will be present...and so, also the opposite:
A weak induction and low power output will generate a weak or very low Lenz effect.
Ufopolitics
―Leonardo da Vinci
