Ufopolitics
By the way...
I ordered some new toys...arriving some time next week.
A brand new Rigol 4 Channel Digital Scope and another Current Probe (Tektronic A622) identical to the one I have...
So, I want to take serious measurements this time...Two Clamps measuring In-Out Amps...at the same mV range
Plus two Passive Probes on In-Out Voltage...
All in one Scope.
We would see...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
magnet1c
Quote from: BorisKrabow on July 19, 2022, 02:48:39 AM
Hi  nix85
           Let's look at two simple examples.
          1   A classic device that works according to Lenz's rule. The magnet approaches the coil. The magnetic field in the coil increases and if the electric circuit is closed, then the coil begins to counteract the magnet with the same field as the magnet.
         2    A device that works according to other laws.The magnet approaches the coil. The magnetic field in the coil decreases and if the electrical circuit is closed, then the coil begins to contribute to the movement of the magnet with the opposite pole than the magnet .
               https://overunity.com/15307/lenz-free-generator/msg564776/#msg564776
              it is very simple and has been in the public domain for a long time   :) . I hope in the near future many people will have free energy .
                   Best regards Boris
It can be done and as i said i proposed a similar idea few years ago, by placing
a weak magnet on its side inside the coil, or two magnets back to back with piece
or iron on top, we need to cancel repulsion when rotor magnet enters the coil and
attraction when it leaves.
I read your post, it is not clear how you imagined that rotor magnet passing in 3D
and more than that explanation is not clear how you imagined that will produce
reverse lenz.
If that steel plate is of any significant thickness it will suck up all the magnet
flux and coil will not see any.
I do like however and have for a long time been pondering on similar combinations
to use attraction to iron to counter lenz and such ideas existed for a long time
before you or me thought of them.
Also closely related is a use of iron to make opposite poles stick together...
Those are all good interesting ideas.
nix85
BorisKrabow
hi all !
            It is clear that other tests are needed. Feedback from other researchers about their experiments on the Lenz reverse is also needed. Without numerous checks and successful replications, this technology is unlikely to be mass-produced.
            My device was designed to search for the Lenz inversion effect. Of course, a working prototype must have a different design.
           I have an idea that the technology demonstrator should be a pendulum.
     The pendulum increases the amplitude of its movement when a load is connected to it (incandescent lamps). There are no connections to power sources and measuring instruments.
             I must add that the device I presented is the only one that showed the reverse effect.I made many attempts to change the design and arrange the parts differently ......
      Those researchers who want to repeat or change the design should remember that Lenz's law is stronger than it seems.
                                                       I'm sure free energy will soon be readily available.   :)
               Best regards Boris
rakarskiy
What do you have under the Lenz Force? If the electromagnetic force, then this is not Lenz, this is the Ampere force!
All. that in education. associated with Lenz as the braking of the generator, complete nonsense, made on purpose, I already know this for sure.
Recording:  E = -dФ/dt,   is inherently incorrect, since if for a conductor connected to the battery (or in the generator phase) it will look like:   dE = -dBi/dt
For a generator, in order to form an EMF, the record has the form: dФ/dt  = -dE,   [Ф = BmS]
Now think about what is primary in the electromagnetic induction of the generator? [ E = -dФ/dt ????????????]
https://rakatskiy.blogspot.com/p/ampere-force.html
alan
Lenz only describes the direction of Ampere.
What is the reason that you wrote dE?
