Ufopolitics
Hello  to All,
Ok, so, continuing on the Lenz "saga"... :)
In my opinion, and in order to understand what these non rotational systems do related to this law...We need to separate Lenz into two parts:
1- The physical side effect, which could be seen anywhere we look at...Generators, Motors and Transformers, even the later one, not having any moving part(s).
This physical side would be easier to understand  from any N-S Magnetic Interaction point of view, no matter where we set the individual N or S poles, whether at Rotor or in Stator, So, all this "Locking" physically of the Rotors is plainly and simply caused by Two Magnetic Fields in Attraction mode.
2- As a Direct consequence of the Physical side, or as a "Direct Response" to, We get a demand of higher currents from our Input side, in order to compensate the System to "equalize" back to normal operation.
Permanent Magnet Systems are ALWAYS trying to look for a balance of Forces by themselves no matter what, without absolutely any external help...We have seen it in all attempts done through history, in order to get a perfectly self-running Magnet Motor.
And so, since we are playing with Magnetic Systems as well, on any Electromagnetic Machine, we have exactly the same balancing principle applying...
1-a : Any Motor, once loaded mechanically, increases Lenz physically and as a result, Increases Currents, due -directly- to a Rotor forced to slow down physically, which causes magnetic interactions to "acumulate" or delay related to Space-Time progression.
1-b: The same exact deal as in a Motor, takes place in any Rotary Generator...
1-c: In a Transformer, even it does not have any moving parts, we obtain the same "Lenz Effect #2", so, current rises in our Primaries, whenever we load the Secondary or Output end.
How come?
Well, the answer is simple, we have Both Magnetic Fields (Input-Output) locked down and Static, caged and bound to the same, commonly shared steel frame.
IMHO, a Transformer principle, is just like a "locked generator" except the windings are calculated to stand the Input-Output currents range, and the bulky steel frame for heat sinking, without the need to rotate.
So, first, digest all this, I have put it in simple words, without any math formulas...in order to understand it better...and not making a long post...
So, I will continue with Non Physical Rotational Generation Systems next...
Best regards
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Part 2...(Cont)
Non Rotational Energy Generating Systems and Lenz...
Again, this is only my opinion, as I have proven all my work on these Systems for a long while...even though I have not being able to prove a full and steady Overunity result...for those "knowledgeable in the Arts", know that I am very close to achieving it...
On these Systems, the Lenz reacting Field is set to be fixed to a Stator steel frame, while the "Non rotary Rotor" steel frame and copper coils (sorry about the redundance), are in charge to Transport the Magnetic Field Spectrum through its mass...
And this is where the advantage simply lies...where we have a Frictionless, a Massless Field, which could travel through Space-Time with zero friction, zero heat generation (except for the heat produced by currents running through the copper wires, which is very fast sinked on the steel frame).
This is our way to compensate for Lenz reaction, period.
The rest is all related to the original principles, where by simply driving this "Ghost Field" through any mass, faster and effortlessly, it will fight Lenz reaction, which we have caged in Space-Time fixed position.
Lenz will jump and Hum in a Tantrum, like there is no tomorrow...but there is nothing it can do against such a fast displacement of the massless Field...and Currents will do come down at Input, while Increasing at Output...the same way we achieve it on the typical Rotary Generator...except here we do it much easier and less Energy spending in Gasoline and Heat generation.
This is plain and simple guys....and all you need to do, is stop talking here, and get your hands on the freaking Bench...and build it!!...so you all can see it with your own eyes what I am talking about.
And like any surging, new technology, it needs a lot of dedication, a  lot of calculation to make it perfectly stable...
And so, I am working on it...Now...Are You?
Sincerely
Ufopolitics
―Leonardo da Vinci
Lunkster
Hello,
Since the Holcomb generators use a traveling magnetic flux wave,
can a hybrid configuration of PMs and (EMs or coils) be used in the design?
Would the usage of PMs along with the (EMs or coils) be more efficient
than a design without PMs in it?
Would not a configuration of PMs and Active EMs produce a functional PM magnet?
The drawing is just a crude first thought of what it might look like.
I am sure there would be better designs.
Lunkster
