bistander
I also have attempted to contact DNV, several times, a few months ago, with no success. I believe the verification claim and certificate they showed are false.
bi
stivep
some explanation  of terminology used by rakarskiy
I hope it helps.
Quote from: rakarskiy on July 30, 2022, 01:03:53 AM
his OU is just the effect of magnetic amplification in "electrical steel."
All according to academic science.
All according to academic science OU device doesn't exist and that's why OU doesn't have any properties.
There are two fields (the field from the excitation flow and the field from the phase under load) that need to be connected.
I already know exactly why this requires a triangular excitation waveform. This is the difference between a transformer and a generator (AC) or similar (DС). But in any case, the main obstacle to holding the EMF signal shape and the excitation current is the non-linear inductance parameter of the excitation electromagnet coils.
so   are you  saying:
linear triangular signal is used for #1"excitation flow"
and
#2 "field from the phase under load."
please explain what you understand by #1 and #2
Quotetriangular excitation waveform. is:
non-sinusoidal waveform named for its triangular shape.  It is a periodic, piecewise linear, continuous real function.
Like a square wave, the triangle wave contains only odd harmonics.  However, the higher harmonics roll off  much faster than in a square wave (proportional to the inverse square of the harmonic number as opposed to just the inverse.  https://en.wikipedia.org/wiki/Triangle_wave
Quotenon-linear inductance is opposed to linear.
linear is air coil where inductance  is independent from current flow. the best explained here:
https://youtu.be/e26A3-V19Nw
The whole reason is to create a linear rate of change of flow from zero to maximum and from maximum to zero.
For any non-linear change in speed, the phase EMF graph will immediately respond, and not for the better.
So non-linearity is caused by (I assume " electrical steel") ferromagnetic conductive material core.( of a transformer)
Is that the DC  saturable offset   controlling AC   explained here? :
https://www.sunpower-uk.com/glossary/what-is-magnetic-amplifier/#:~:text=A%20magnetic%20amplifier%20is%20an%20electromagnetic%20device%20that,with%20two%20or%20more%20coils%20wound%20around%20it.
magnetic amplification in electrical steel.
Effect of magnetic amplification is very interesting and explained here:
https://en.wikipedia.org/wiki/Magnetic_amplifier
https://www.elprocus.com/magnetic-amplifiers-principles-and-applications/
Quoteelectrical steel.  is the descriptor used  by  Holcomb
- they have found a new energy source called "electrical steel" which (are you sitting down?) is made of iron with small traces of silicon, manganese & aluminium.  I suppose the key ingredient and what makes electrical steel special is the clever and carefully researched addition of the word "electrical" on the front of the word "steel".https://boards.straightdope.com/t/holcombe-energy-systems-the-new-steorn/959192
Wesley
listener192
Quote from: bistander on July 30, 2022, 09:00:40 AM
bi
Here is the individual stated on the DNV certificate.
https://www.linkedin.com/in/chad-rektorik-b504069a?trk=people-guest_people_search-card
Regards  L192
onepower
Some notes of interest in the HES technical paper...
QuoteTherefore the weak magnetic field generated by the power input creates powerful moving magnetic fields which are responsible for generating electric power.
This is in line with what many other inventors have claimed whereby the inputs weak magnetic field generates a more powerful magnetic field. However there is no requirement that the field(s) rotate and many past devices were linear such as the Cook Coil. Rotation is simply more convenient for timing and higher frequency operation.
QuoteTherefore we get the magnification effect 250 times per second.
Many people misunderstand the power capacity of these devices which I touched on a while back. Each cycle produces X gain in the input versus output which is generally a set variable. Therefore the total energy output is based on how many cycles can be generated per second or Hz. As such a better designed device which could increase the cycles/second from 250Hz to 500Hz would generate twice the energy output.
This is important because it shows the gain mechanism is generally fixed while the energy output is not. More so the gain mechanism is generally set within a fixed set of variables/parameters and it is the frequency of operation as gain cycles per second which determines the output. Here we should understand the COP is different than the output capacity as the COP only relates to the efficiency of the gain mechanism.
In effect the COP is an artifact from non-free energy systems where the efficiency of the transformation determined the output. This is not true of these systems which could have a marginal COP like 1.2 but a high output capacity so long as the cycle rate is very high. Which leads to some confusion when we try to apply old conventions to new technology. Think of it this way, if the output feeds the input it's looped in a circle and a circle has no beginning or end. Thus there is no input vs output or COP only the rate of conversion in cycles per second or Hz. Better put, what is the efficiency of a free energy device generating energy with no external input?...
AC
rakarskiy
Quote from: stivep on July 30, 2022, 10:43:35 AM
I hope it helps.
so   are you  saying:
and
Wesley
Magnetic amplification in electrical steel (a simple chapter from a physics textbook): https://rakatskiy.blogspot.com/2022/06/magnetization-of-steel-magnetic.html
[Electrical steel, also called dynamo steel, transformer steel, silicon electrical steel - an alloy of iron, usually with silicon, sometimes alloyed with aluminum, the finished product is produced in the form of thin sheets with a thickness of 0.05 to 2 mm.]
EMF (E=BLV) depends on two factors: 1) the magnetic induction (B) penetrating the conductor (L), and 2) the rate of change (V) penetrating this conductor (L). This speed is not the same along the entire curve of the sinusoid, it is non-linear. The linear signal is the rectilinear component of a triangular pulse.
A magnetic amplifier is a switching device, before the advent of semiconductors, it was widely used to control power in AC circuits (especially in railway transport)
PS
A picture from my book off the cuff. Everything is checked and justified.
