Lunkster
Hi All,
The same question of how can there be more output than input for electrical generation to occur in the Holcomb system.
There has been many good examples and graphs of how the electrical steel works.
This is the way I see how the Holcomb Systems are valid OU systems.
I have added three sketches that hopefully will help to see how electrical energy is generated.
It is not a matter of electrons increasing because it is a mechanical to electrical conversion of the process.
So the operation of the generator in the area of the electrical steel graph produces more electrical
energy than the mechanical energy used in the electrical steel.
Drawing One:
Now if a person has a hand crank that he is turning a small generator, the generator can power a light bulb that generates photons that lights up the room for as long as the man is turning the crank.  Where does the electrical energy come from?  Do the magnets in the generator supply the electrical energy that can be produced forever in this system?  Does the copper wire have enough electrons in it to operate the system forever?  Does the arm of the man have the electron flow that will operate the system forever?
The hydro dan has water performing the torque to turn the electric generators.  Do the electrons come from the water?
Both in the hand cranked generator and the hydro dam generates the electrons in the output of the generator the same way.
Asking the free energy people where the electrons come from for their generators when the person asking the question does not have a good idea where the electrical power comes from for today's electrical power generation. This is not a fair question to ask them, as I see it, because we all use devices that we do not have a full functional understanding of how they work.  But I will try to explain it anyway for you.  I want to tell you the theory of how and where the energies that operate my generator come from and how they are used in the generator.
There are two energies used in the Motionless Switching Magnetosphere Electric Generator.   The power of flux from the permanent magnet is the torque that pushes the electrons down the wire of the generator.  The other is the "zero-point energy" that backfills the wire with electrical energy so that it can later be pushed to the load and used in the circuits load.  Remember that this open system energy can have other names to it.
The generators energy comes from the atomic level where the atom has electrons moving all the time in them.  For as long as atoms have existed, electrons have been moving in them.  As long as the atoms exist, electron movement will occur.  So, this new technology is a way to use this energy in a way that can produce electrical energy that can be used in unlimited devices.  To do this in a practical way, we need to have this action in a larger scale that makes it easier to access.  This is done by making devices that cause the electrons to move in the same direction.  This is done in producing permanent magnets and electromagnets.  The rare earth permanent magnets today will last longer than a lifetime if handled properly.  When a magnetic field moves by a conductive metal, an electric current is developed in the metal.  That metal can be shaped into a device like a coil of wire to better utilize that current flow so that it can perform work.
Drawing Two:
This drawing helps me to understand how a generator takes power out of the zero-point energy and places it into a wire.  One could argue that it is not zero-point energy but static charges placed into the wire.  Either way, it is an open-source system.  Either way, it does not matter where the open-source energy comes from as long as the output electrical energy is larger than the input energy producing an over unity generator.  The open-source energy may make a difference whether the generator can be used in space or not.  For now, I am only interested in it working on earth where people live and work.
The next generator drawing does a better job of showing the zero-point energy being everywhere.  It makes more sense than seeing electrical energy coming from an arm in a hand crank generator or from water in a hydro-dam.
Drawing Three:
This drawing is another way of looking at how zero-point energy functions in electric generators.  As flux moves across wires, electrical energy is fed to the load.  The zero-point energy that is all around us, backfills into the copper wire at the speed of light.  The input power needed to operate a generator is used to move the flux across the wires.  It then goes to the load in order to perform work.
Now zero-point energy or any of the other names given to it has been talked about for thousands of years as an energy all around us.  It has only been the last few hundred years that it has been ignored because most of the instrumentation for electrical and magnetic forces do not detect zero-point energy.  So many people thought it was fiction.  But to my understanding, today there have been tests done in laboratories that prove that there is zero-point energy all around us everywhere.  So now that we know that energy is there, we can understand how generators get their energy from now.  When the permanent magnets in the generator is moving the electrons through the copper wire in the generator, the void of electrons in the copper wires are quickly replaced from this energy source.  So, our electrical energy always has been coming from this zero-point energy source.  So, I am not using an energy source that we have not been using for years already.  This new technology is a way to get larger electron movement from a smaller electron movement.  Now there are currently transistors, FETs, vacuum tubes, and other devices that already control larger electron flow with smaller electron movements.  What I am doing different is that I use the smaller electrical energy to create a magnetic field that controls flow of several magnetic flux flows.  When you add up all these flux flows that are being changed, it is a lot more than the magnetic field that caused them.  These changed flows are then routed through coils that generate electrical energy.  The collective electrical energy is much greater than the electrical energy to power the switching electromagnet in the generator.  You can use a small percentage of the electrical energy to drive one switching coil and that action will cause electrical energy generation that is several times that control energy.  That additional energy can be used to supply energy to several other devices.  This is an open over-unity system. This is an open free-energy system.  This is a self-running system.  The following two drawings are designed to make it easier to understand how the two modes of the new technology operate.
A closer look at the energy that is all around us that has many names to it is a very interesting study.  What is so amazing is not only is it unseen but conventional electrical engineering equipment cannot be used to measure it.    There are several non-conventional devices that access this energy as an open-source system.  After researching many papers on this energy, I have a lot more confidence in this open-source energy generator design.
rakarskiy
Interesting waveform observations on Holcomb's machine. I categorize them as shown on the slide. The second slide is current waveforms on electromagnets with different inductance of the smoothing choke in my installation.
Feb2006
Quote from: stivep on August 01, 2022, 01:24:44 PM
Utilization of  given fixed amount of energy available from the source even in the most efficient way,  sooner or later dissipates  all of it.
example: car gasoline tank, will at some point be empty.
Can you explain,  the "steel cores and electron spin process" in Holcomb device, e.g based on their patent, (if there is any patent explaining it)
Please provide me with  Holcomb patent number explaining this process.
Wesley
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg569063/#msg569063
onepower
trueresearch
QuoteI find your analysis and suggests interesting. . . .  To take it one small step further is that in your hypothetical
example of using the "hydrogen gas" to lift a mass to 30 km is that at that altitude the gas SHOULD be fairly
pressurized so perhaps releasing that pressure through a turbine as it is burnt would harvest even abit MORE energy. . .
Indeed, the more we look at a problem with an open mind and consider all the possible external
conditions involved the more practical solutions we can find.
I believe it was Faraday who came up with the notion of lines of force and closed systems.
However as Faraday implied this was only so we can simplify the extraordinary number of calculations
involved and was never meant to be taken literally. However many did take what was said literally and
made the mistake in thinking all systems are closed when in fact none are.
For example, all material stuff including us is under a magnetic influence in some way because they
are immersed in Earths magnetic field. We can pretend it doesn't exist or matter but in fact it does
exist as a matter of fact. We and everything we know on Earth are immersed in electric and magnetic
fields as well as cosmic radiation and high energy particles traveling through the Earth as if it wasn't
even there. These are the fact we know and it only gets stranger from there, lol.
AC
ariovaldo
I just fried 3 PLC output I/O in the SLC.
Looking to install an IGBT driver photocoupler.
I hope next week I can start to test.
