SolarLab
Quote from: stivep on August 03, 2022, 05:02:38 PM
If there is any use from any technology converting energy from one form to the other
than that is good for all of us.
While trying  to understand what Holcomb is about it is helpful to analyze it based on
the same principals  as all technology around us.
and that is physics and its rules.
Wesley
Build a Holcomb and test it - should only take you an hour, a bit of wire, some steel and a 4 channel logic analyzer
and 4 MosFETS if your logic analyzer has a weak output (most can drive a good load).
It's not too complicated and nearly any soft steel will yield results. Having a lab at hand also helps a lot.
ramset
A layman would say
I can't find Free Energy in the physics rule book
Which page is it on ?
Actually it's not in the physics books
Nor is Over unity !
Hopefully some pages will be written
Once the actual gain mechanism is understood !
BTW
There is an open invitation to member Jimboot to see the tech in a Florida location ,
Not at HES facility?
Respectfully
Chet K
Tolerance please!!
Edit
Edit for comment below
We just might have this accessible in a Florida lab ( a bit dormant / inactive  at lab for the moment)
And we might have a builder with incredible experience in "this thing we do "
Available to facilitate this build you suggest  !?
Thanks Grandma
SolarLab
Holcomb's "fuel source" is understood by examining the B-H curve [posted in full a while back] of
soft iron and is clearly described in the HES Technical Summary [posted in full a while back].
This is the "Gain" mechanism - magnetic domain alignment in conjunction with magnetic field rotation!
Part "III" attached below:
"However, when a coil of magnet wire is wrapped around the electrical steel, and a weak current is passed through the coil,
the coil generates a weak magnetic field which aligns the magnetic domains of the steel, and as the domains are aligned,
they produce powerful, moving, magnetic flux which, when organized and sequenced ..."
Jimboot
Quote from: SolarLab on August 03, 2022, 05:48:59 PM
My understanding is that the strength of the field is determined by voltage (AT) & frequency but is not dependent on current? Which is another reason I like this idea.
stivep
I think the confusion here is about my position the Holcomb technology.
I never criticized Holcomb .
I would love him to succeed.
The time will prove who's right and who's wrong.
_____________________________________________
Provided by solarlab text is understandable to the point of talking about electron spin.
External magnetic field e.g from quote : "coil aligns magnetic domains." - true
but that needs external energy .
From that point, nothing is clear any longer in this text.
We may think that Holcomb is extracting energy from.. From what?
magnetic domain?
free electrons,? – this can only move under external force called voltage- difference of potentials.?
I am in disagreement with statement that Holcomb energy source would never end.
There is no such thing as conversion of energy from empty car tank, or empty bucket.
Contribution to the subject should be seen as a value coming from critics as this makes all of the others to think and respond.
I wish Holcomb to become another Albert Einstein.
Wesley
