r2fpl
Quote from: rebar on August 07, 2022, 08:12:15 AM
The other issue they have is that they claim to extract energy from electron spin of an iron atom. You cannot extract energy from a static field.
Holcomb and Arkady Stepanov also talk about similar possibilities.
In order for the static electric field to do the job, it must go to ground then it will do the work usefully.
rebar
ariovaldo
If someone knows exactly how the Holcomb device works, I don't. As a weekend hobbyist,  I built a PLC/MOSFET driver with just three outputs. This test is to exercise my two neurons and learn the effects. I'm starting to put it together to simulate the magnet passing in from a coil.
I will try different configurations to see the results.
By the way, I received a quote from Polaris, a linear laminated core with slots and a general size equivalent to a 20 HP generator. $8K.
https://youtu.be/T9xZGh-_cRc
ramset
Here it seems a moderator will have to be placed !
To protect forum from lawsuits
It is completely different circumstance to investigate a claim ...
It implies no endorsement, just research .
However writing con ,scam ,fraud ,etc etc or implying such ..
Will bring lawsuits to forum ( Stefan).
Terms of service agreements forbid such activities
Non negotiable!
Thanks Grandma
rakarskiy
Electromagnetic generator - ANY, works only on the law of electromagnetic induction. If you don't know how this process (electromagnetic induction) works, you don't know anything about electric generators at all.
First, understand the points by point how an electromagnetic synchronous generator works, in which the phase windings are laid in grooves.
Specify how mechanical power (Pk=Fv) is converted to electrical power (Pe=IU).
In general, why did the Gramme generator with an external winding lose to generators with a groove furtively of the phase wire?
If you do not know this, then your accusation of fraud of the one who made the generator (demonstrates it and, in addition, sells it to customers for whom it works) can be regarded as fraud or trollism, in favor of the energy companies.
