rakarskiy
Quote from: alan on August 10, 2022, 08:58:57 AM
If BVL results in E [V/m], then (B/dt)VL results in E/t, [V/ms]
just a guess  ;)
In fact, this is an algorithm for solving the problem, both for a mechanical and for a solid-state generator  :D
Ufopolitics
Quote from: rakarskiy on August 10, 2022, 11:33:47 AM
just a guess  ;)
Hello Rakarskiy,
V=Velocity=Speed=RPM's...plus Acceleration...Are ALL functions TOTALLY DEPENDENT OF TIME.
So, Nope, You can NOT establish (-V ---------->+V) in a completely VERTICAL line, meaning Time=Zero=0...or totally ignoring it travels through TIME.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
rakarskiy
Quote from: Ufopolitics on August 11, 2022, 08:19:47 AM
Hello Rakarskiy,
Ufopolitics
UFO Hello!
Take, make a mathematical model and calculate the floor of the EMF pulse period.
Speed is not time, it is the amount of change in magnetic induction over time. This means that if the magnetic induction is constant (for example, maximum) in the time interval, then the rate of change is zero, the EMF will be zero.
There are many interesting things in this topic.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg569443/#msg569443
Ufopolitics
Quote from: rakarskiy on August 11, 2022, 10:09:02 AM
UFO Hello!
Hey Rakarskiy,
QuoteSpeed is not time, it is the amount of change in magnetic induction over time.
Now, just read the bold out words only...
Man, You are contradicting yourself with so many formulas...hahahahaha
In my opinion, to get Induction constant We need the simplest equation provided by Faraday...change of flux over change in time (dFlux/d/Time)
And that, in simple layman terms is to move the Magnetic Field over Space/Time...
Now that movement could be back and forth or reciprocating...or rotational (continuous)...
Figuera did it based on increasing and decreasing field strength, so this effect would expand-shrink field through Space/Time in like a reciprocating way.
This whole thing works like a fluid mechanical pump...but we are "pumping electron flow"...by moving field over space/time...
Take care friend.
Ufopolitics
―Leonardo da Vinci
rakarskiy
UFO hello!
Yes, it sounds like a contradiction, but that's if you don't know what "rate of change" means.
In a mechanical generator, this property is rigidly tied to the mechanical movement of the magnetic pole to the wire in which induction occurs.
We can say that the linearity is achieved by the uniformity of the movement of the rotor poles.
The curve of the graph of EMF and magnetic induction must match. But in order to achieve this, it is necessary to withstand the rate of change of magnetic induction in one interval of the pulse. This change should be linear. The sinusoid is already, not all completely linear. There is a speed reduction at the tops, allowing for a transition curve.
As you deal with this, get the physical concept of a rotating magnetic field, at the moment the load is connected to the generator terminals. This rotating field is vortex.
Sincerely.
