rakarskiy
The whole problem is that the resistance of the conductor and the load is the resistance of its crystal lattice to the formation of a vortex magnetic field.
The electric field is a surface phenomenon for metallic conductors. You are well aware that these fields are parasitic for electrical engineering. To protect electrical appliances, the flow of electrical field formations into the ground is used. This is a grounding device.Electromagnetic induction is a circuit phenomenon when an existing electric field (internal element for dielectrics) is formed with a potential difference on metal contacts (surface element) closed in a circuit between the terminals and, in contrast to the movement of the electric field, arises to balance (magnetic vortex field). It is this moment that is written in the formula of electromagnetic induction:
E = -B  or  E = -Ф  =  [1V = -1Wb]
1V is the value of the electric field potential difference.
The force to balance the potential difference of the electric field, most likely arises from the Coulomb's Law  https://en.wikipedia.org/wiki/Coulomb%27s_law
Electromagnetic induction of EMF guidance from a magnetic flux, this is the reverse process:  Ф = -Е
The emerging magnetic vortex field, in fact, does not oppose the movement of the electric vortex flow, but rather accelerates the process.
By increasing the resistance of the circuit, by introducing a consumer load, we ourselves slow down this process. This is actually energy, to stretch the process of balancing the potential difference of the electric field, and use the magnetic vortex sweat for consumer purposes. If we do not introduce an increase in resistance, we get a very powerful balancing process with the formation of a very strong and destructive magnetic field, which you know as a "short circuit", i.e. our conditional twisting of the rope leads to its destruction.
The conductor and load resistance works like a twisted rope. By the way, those who are well versed in the topic and know everything about the skin effect will understand me more, I hope.
Just because the electric field will not move, the movement of the electric field is associated with a vortex. EMF is a vortex structure. The conductor creates a counter vortex magnetic field.
For me personally, there are several questions that have not yet been fully clarified. Current strength (vortex magnetic field) is a mandatory phenomenon or there are exceptions. Episodes are known when the Electric field was transmitted in a loopless version, without a vortex magnetic field (current strength) along one wire.
kolbacict
And where, in this case, does the voltage appear at the ends of the coil during its sharp braking?
There are no magnetic fields there. Perhaps they were specially shielded for the purity of the experiment.
rakarskiy
Quote from: kolbacict on August 22, 2022, 02:20:42 AM
Question for backfilling, how does a charge appear on an ebonite stick?
The unwinding of the conductor in insulation, the insulation in motion and its abrupt change in movement are probably the source of the electric potential.
kolbacict
Quote from: rakarskiy on August 22, 2022, 02:26:52 AM
In such a case, there must obviously be the same potential at both ends of the coil. After stopped it.
But we have a potential difference.
rakarskiy
Quote from: kolbacict on August 22, 2022, 03:10:04 AM
Вольтметр не меряет электрические заряды, он меряет разность потенциалов.  :D ;)
