0 Members and 75 Guests are viewing this topic.
stivep
Quote from: rakarskiy on August 21, 2022, 05:53:08 AM
// a change in magnetic flux through a closed circuit at a rate of one Weber per second induces an EMF in this circuit //
Current Force//manifests itself in the action of electromagnetic induction in a closed circuit.
//orthodox all agreed // this phenomenon as the movement of electrically charged particles is not confirmed in any way.
The current strength is directly related to the vortex magnetic field around the conductor.
From here we conclude that the current strength in the electrical system and the eddy magnetic field around the conductor are one and the same phenomenon, only in different measurement systems.
The movement is carried out by an electric field between potentials, and a magnetic vortex field (current strength) is a consequence with a different spin vector.
I don't want long discussion with you just read this please:
Chirality in real time
QuoteThe method commonly used to detect enantiomers is circular dichroism (CD) spectroscopy.
It exploits the fact that light polarized into a circular wave (like a whirlpool) is absorbed differently by left-handed and right-handed enantiomers.
where light - is electromagnetic  (and not magnetic) wave!!
if there is no electric field than there is no EM wave.
https://phys.org/news/2019-01-chirality-real.html
-your  vortex is not something unique
This one you would like:
https://database-physics-solutions.com/lecture/lect2_magn.php
the Law of the total current.
Vortex  nature of the magnetic field Circulation of vector an arbitrary closed loop is the sum of current covered by the circuit
electric field, for which the circulation of the vector equal zero and the electrostatic field is potential,  the circulation of the magnetic field is  not zero
Solenoid is cylindrical shell, which are wound windings of  wire.
Consider an infinitely long  solenoid, ie solenoid which ℓ >> d, where ℓ  - length , d–diameter of the coil.
Inside such a  solenoid magnetic field is uniform. Uniform is a field, the field lines are parallel and their density is constant.  !!!!
-if a path on which we consider the  circulation covers currents.  Field, the circulation of which is non-zero, is called a vortex or solenoidal.
Consequently, the magnetic field is a vortex.
In  vortex field force lines are closed, therefore, there  is no magnetic charges.
The section § 4:
-A  magnetic field the solenoid and toroid is worth to be read too.https://database-physics-solutions.com/lecture/lect2_magn.php
https://database-physics-solutions.com/lecture/lecture_physics.php
additional material for your interest:
https://www.bing.com/ck/a?!&&p
Problems with vortex:
some basics for you- https://physics.stackexchange.com/questions/645871/the-direction-of-the-magnetic-field-around-a-conductor
Magnetic vortex core reversal by excitation with short bursts of an alternating field
Quotea curling magnetization, is one of the equilibrium configurations of soft magnetic materials// the exchange energy
QuoteThis curling magnetization turns out of the plane at the center of the vortex structure, in an area with a radius of about 10 nanometres—the vortex core
vortex // specific excitation mode: the in-plane gyration of the vortex structure //
controlled manipulation of the vortex core polarization is done by excitation with small bursts of an alternating magnetic field
//switching of the out-of-plane core polarization
curling%20magnetization
Wesley
rakarskiy
Wesley, thanks for the reply! But I didn't convince, the more I immerse myself in this issue, the more the electronic version collapses. As for the solinoid, the same interesting feast. solenoid is inductance
L = Ф/I  (1H = 1Wb/1A)
By the way, it is the solinoid that forms the vector magnetic flux, and if the solenoid has a core, it also has an independent core field. For me, this is a closed issue.
SolarLab
 F Y I
Further development of the Holcomb varient (LinGen, amongst others)
by Solarlab, et. al. has been moved to a wide bandwidth Web Page type
environment to allow for more content, video streaming with indexing
and easy browsing.
Thanks go out to the OU folks for hosting this "Holcomb Energy System" thread.
Watch your PM for further details.
Best regards and good luck in your quest for OU!
Solarlab
e2matrix
Quote from: SolarLab on August 29, 2022, 02:13:53 PM
F Y I
and easy browsing.
Solarlab
Can you post a URL here?
rakarskiy
Quote from: rakarskiy on August 27, 2022, 03:38:53 AM
Such an interesting moment! The first position of the EMF form is fully confirmed for the solid version, where the saturation in the core changes.
Someone noticed it, or no one paid attention to it.
This is the essential difference between a generator and a transformer.
In the first position of the Naudin diagram, I doubted, since I received this form of EMF only when the magnet was removed and approached the core of the coil along the central axis of the magnet and the coil.  The second time I got it already in solid-state version.
If the magnet is located on the rotor, the shape will be with humps (the same shape was obtained by Bedini on the Kromri generator). In electrical engineering, in order to avoid two humps, a special rounded shape of the tip is made to obtain an even half of the sine wave.
Slides of one researcher, I put his drawings together.
