0 Members and 43 Guests are viewing this topic.
Ufopolitics
Quote from: Floor on March 26, 2022, 09:27:29 PM
Still, I see no simplified explanation of, or theory of operation presented here.
Does someone have one ?
Hello Floor,
I believe I have explained it before...but is ok, my  pleasure to explain in more detail.
Honestly, I find it so simple, that I do not see it as that hard to understand...
It does  not affect -at all- Faraday Law of Induction...same parameters apply without absolutely any change...
For better understanding, let me brake it down in two parts, a Physical and a Virtual .
The Physical Switching consist of single coils which are connected isolated into series of Pairs, set at 180º apart across (whether output stator is inside or outside), and here the "Higher the Resolution" (as Pierre Cotnoir mentioned), the more compact of a field we will have...Higher Resolution meaning higher number of coils around the 360º, to then  nbe divided in Groups, depending on the total number of poles we are working with...say in a 36 poles rotor we choose six groups of six independently excited coils, so each group will have 60º, as each coil have around 10º.
Meaning we have Six Groups which are going to be switching NNNNNN-SSSSSS-NNNNNN-SSSSSS-NNNNNN-SSSSSS spread along the 360º every 60º
Now to start the Virtual Rotation we start reversing three pairs of two single coils simultaneously @ 120º apart...and so on and on...
And the point here is to switch only one single coil per group at a time, this way the magnetic field of each group will never collapse.
Realize that whenever we magnetize a full group of individual coils, next to each others, at the same time, we generate a Single Field,, whether North or South.
The Virtual displacement of the Main Group of Fields is a consequence of above individual coils reverse switching, actually, since we are not allowing the Main Group Field to collapse, it just makes a Spatial Jump to the next level, in this case every 10º  and 180º apart...
If you look at the image below...it may help to understand the geometry here...
Hope you understand it
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Hello II,
What is the difference between alternating current and three-phase current?
https://ladefragen-de.translate.goog/28/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Image result for three-phase current The only difference between alternating current and three-phase current is that three-phase current consists of three alternating currents (L1, L2, L3). These are 120 degrees out of phase. So three-phase current is twisted alternating current.
07/28/2021 Direct current, alternating current and three-phase current: What is that actually?
For VA and VAr power,related DC or Direct Current, the difference to observe and apply ! :
https://ladefragen-de.translate.goog/43/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
https://www.youtube.com/watch?v=T-gFgnG7XU8
https://www.youtube.com/watch?v=yOS5Id0OcKk   and all other right side explaining audio-vid´s
f.e. : https://www.youtube.com/watch?v=qSQO0Y2b2oo
        an asymetrical tri-phase             to symetrical tri-phase
                                                              to
                                       https://en.wikipedia.org/wiki/Polyphase_system
        an asymetrical   poly-phase > tri-  to symetrical poly-phase > tri-
                                by Tri-to POLY-angulation of Power Factor Tri- to POLY-angle
https://www.google.com/search?client=firefox-b-d&q=power+factor+triangle
                                            to finally :  PWM Power
                                     https://www.vishay.com/resistors/pulse-energy-calculator/
here explained for example by P. Kanarev https://www.google.com/search?client=firefox-b-d&q=kanarev+pulse+power
more:
https://www.google.com/search?q=electrical+pulse+power&client=firefox-b-d&sxsrf=APq-WBvabj791bZKCcJ9ZWweqNNnFhWGqg%3A1648350356634&ei=lNQ_Yq-nJoKzsAfJgIjACg&oq=electric+pulse+power&gs_lcp=Cgdnd3Mtd2l6EAEYADIGCAAQBxAeMggIABAIEAcQHjIICAAQCBAHEB4yCAgAEAgQBxAeMggIABAIEAcQHjIICAAQCBAKEB4yBggAEAgQHjIGCAAQCBAeMgYIABAIEB4yBggAEAgQHjoHCCMQsAMQJzoECAAQQzoKCAAQCBAHEAoQHkoECEEYAUoECEYYAFCLClixNWC8R2gBcAB4AIABbYgBhQySAQQyLjEzmAEAoAEByAEBwAEB&sclient=gws-wiz
making part :
https://www.google.com/search?client=firefox-b-d&q=plasma+current
here "current" as "actual" ;)
         https://www.google.com/search?client=firefox-b-d&q=fermilab+current
https://www.google.com/search?q=fermilab+&client=firefox-b-d&sxsrf=APq-WBtq64VMp1sOXDKhOc_4O1nZ8QKntQ%3A1648350728473&ei=CNY_YrfNHIe4lwS4y7iwDA&ved=0ahUKEwi38Yr9qOX2AhUH3IUKHbglDsYQ4dUDCA0&oq=fermilab+&gs_lcp=Cgdnd3Mtd2l6EAwyBAgjECcyBQgAEIAEMgUIABCABDIFCAAQgAQyBQgAEIAEMgUIABCABDIECAAQHjIECAAQHjIECAAQHjIECAAQHjoHCAAQRxCwA0oECEEYAEoECEYYAFDiEFiAFmCpL2gBcAF4AIABbYgB3gWSAQMwLjeYAQCgAQHIAQjAAQE&sclient=gws-wiz
https://en.wikipedia.org/wiki/Tevatron
https://en.wikipedia.org/wiki/Physics_beyond_the_Standard_Model
GRT  SRT    ART ( A = Absolute Relativity Theory)   https://en.wikipedia.org/wiki/Unitarity_(physics)
wmbr
OCWL
pmgr
@partzman et al,
The inner part is a rotor consisting of 16 poles.
The outer part is also a rotor consisting of 16 poles.
The poles of inner and outer rotor are aligned and reinforcing when biased.
These 16 poles are grouped in 4 groups of each 4 neighboring poles,
leading to an overall rotor pattern of 4 magnetic poles (N-S-N-S)
The center part is the stator with 36 slots. Since we have 4 poles on the rotors,
we have 4 groups for each phase on the stator.
Each group has 3 coils in series. The coils are lapped with a span of 6, so e.g. 1-7.
This is the slot assignment for the rotor.
x-y means a single coil sitting in slot x (left side of coil) and slot y (right side of coil)
(x1-y1,x2-y2,x3-y3) means these three coils are wired in series
Phase 1 group 1: (  1-7,    2-8,     3-9  ) facing N pole of rotor
Phase 1 group 2: (10-16, 11-17, 12-18) facing S pole of rotor
Phase 1 group 3: (19-25, 20-26, 21-27) facing S pole of rotor
Phase 1 group 4: (28-34, 29-35, 30-36) facing N pole of rotor
Phase 2 group 1: (13-19, 14-20, 15-21) facing N pole of rotor
Phase 2 group 2: (22-28, 23-29, 24-30) facing S pole of rotor
Phase 2 group 3: (31-1  , 32-2  , 33-3  ) facing N pole of rotor
Phase 2 group 4: ( 4-10,    5-11,   6-12) facing S pole of rotor
Phase 3 group 1: (25-31, 26-32, 27-33) facing N pole of rotor
Phase 3 group 2: (34-4,   35-5,   36-6  ) facing S pole of rotor
Phase 3 group 3: (  7-13,   8-14,  9-15) facing N pole of rotor
Phase 3 group 4: (16-22, 17-23, 18-24) facing S pole of rotor
For each phase, coils in groups are wired in series as group1 - group2 + group3 - group4 (N-S-N-S)
pmgr
@LancaIV
If you insist on posting noise, the least you can do is to keep your lines short so that it doesn't mess up the formatting of everyone else and we don't have to scroll all the way to the right to find the reply button.
Thank you!
unconventional noise output applications  ;) :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=wolfgang+hagedorn&IN=&CPC=&IC=&Submit=Search
DE8901215  Magneton
https://www.britannica.com/technology/magneton
               DE8813063
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1#
related #142  :)
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=3804440A1&KC=A1&FT=D&ND=3&date=19890209&DB=EPODOC&locale=en_EP#
wmbr
OCWL
btw : application,B1 = Award : EP PATENT ! 1993 the decision published !
         https://worldwide.espacenet.com/publicationDetails/originalDocument?FT=D&date=19931006&DB=EPODOC&locale=en_EP&CC=EP&NR=0367760B1&KC=B1&ND=4#
The physical manifestations and phenomena of permanent and electromagnetism,
in particular the attraction of unequal and repulsion of like magnetic poles, induction and the magnetic field are theories that are based on experimental,
electrodynamic and mathematical evidence of laws such as those of Ampère, Coulomb, Faraday , Gauss, Lenz, Lorentz, Maxwell and Oersted.
The Unitarity(Physics)-Model,to ABSOLUTE CERTAINTY  https://de.wikipedia.org/wiki/Gewissheit
                                                 ABSOLUTE RATIO,          https://de.wikipedia.org/wiki/Analysis_fidei
optical demonstrator about laws apply and the orders( pleni-/magni-tude  )
EE and Mandelbrot Fractale abstract to concrete and wise-/vice-versa reflection by 'Licht-/Welle-Brechung'
                                                              typo : wipping balance
EE and https://www-ingenieurkurse-de.translate.goog/physik/kraftwandler/hebel/zweiseitiger-hebel.html?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp relationship,conditio : fulcrum ~ Dreh-/Angel-Punkt or   0-point
        in equity&tribunal law : https://en.wikipedia.org/wiki/Lady_Justice
https://upload.wikimedia.org/wikipedia/commons/thumb/2/2c/HK_Central_Statue_Square_Legislative_Council_Building_n_Themis_s.jpg/220px-HK_Central_Statue_Square_Legislative_Council_Building_n_Themis_s.jpg
https://upload.wikimedia.org/wikipedia/commons/thumb/6/63/El_pesado_del_coraz%C3%B3n_en_el_Papiro_de_Hunefer.jpg/220px-El_pesado_del_coraz%C3%B3n_en_el_Papiro_de_Hunefer.jpg
Ius : Iustitia et Prudentia et Iudiciaria
Mother Nature their wheel/s the giro ::) gear and impulse,steady,nonstop
