pix
Quote from: Floor on March 26, 2022, 09:27:29 PM
Still, I see no simplified explanation of, or theory of operation presented here.
Does someone have one ?
Three coils...
Hi Floor,
Yes, it is basically Holcomb setup. Nothing fancy.
1. Outer coils (green and blue) are : blue-locked rotor concentrated winding (16 pcs),  green- outer stator concentrated winding (16 pcs) . Middle coil mangenta(?)- it is 3 phase motor stator with distributed windings, 4 pole.
2.So outer/inner concentrated windings pair are pulsed by control circuit , then next pair and so on to create rotating magnetic vector that induces EMF in middle stator windings.
That's all.
Cheers,
Pix
pix
Quote from: partzman on March 26, 2022, 07:38:28 PM
UFO:  I have to agree with what you say.  I would like to hear more about what you have seen as a working OU device.
Pix: How many sets of coils do you see in the Holcomb generator you posted?  I see a rotor, stator, and a third set on the very outside.  What is the function of this third set?
Anybody have an answer?
Regards,
Pm
Partzman.
I already explained it in my previous post with a pictures.
3 ferromagnetic cores.
In the centre there is a locked rotor with 16 concentrated coils- then outside is a stator with another 16 concentrated coils. Those two are generating rotating magnetic vector, controller is pulsing adjacent concentrated coil pairs one pair a time I guess, to create rotating magnetic vector.
Between them we have a middle stator with distrubuted coils, it is regular stator from 3 phase motor. Here in that middle stator rotating magnetic vector is inducing EMF, from that windings we take generated power.
Simple like that.
Holcomb setup is mimicking Permanent Magnet generator or normal 3 phase motor with permanent magnets attached to the rotor.
Only difference- no need for mechanical rotation of the rotor, Holcomb creates magnetic field rotation by control circuit pulsing inner/outer cconcentrated coil pair pulsing.
I don't see anything extraordinary in that setup, neither a reason to be OU.
Cheers,
Pix
r2fpl
https://holcombenergysystems.com/wp-content/uploads/2020/03/Technical-Summary.pdf
...In comparison, the HES alignst the domains and   relaxes the alignment, and re-aligns and
relaxes continuously every 4   milliseconds (250Hz) . Therefore we get the magnification   effect 250 times per   second.
The key = relaxes
seychelles
THIS INVENTION CAN BE VERY EASILY FURTHER ENHANCE BY MARRYING THIS GREAT INVENTION
TOGETHER. IT WILL TAKE A PURE GENIUS TO DO SO. https://www.voanews.com/a/can-better-electric-motor-save-planet/4235140.html
