pix
Quote from: r2fpl on March 27, 2022, 06:07:36 AM
https://holcombenergysystems.com/wp-content/uploads/2020/03/Technical-Summary.pdf
...In comparison, the HES alignst the domains and   relaxes the alignment, and re-aligns and
relaxes continuously every 4   milliseconds (250Hz) . Therefore we get the magnification   effect 250 times per   second.
The key = relaxes
Magnetization and demagnetization of ferromagnetic material may be this novelity in Holcomb? :o
Every flyback and boost converter is doing this.
If we want  talk about energy gain, we should talk about utilisation of non linear region of magnetization curve, and only that region- then yes, there is amplification there. But I don't see it in Holcomb setup. For that nonlinearity we should use very soft magnetic material with small demagnetization losses.  Such material should have high saturation point, above 1,5Tesla and very narrow hysteresis, nanoperm would be good.
And device should operate only in that nonlinear region, not going into saturation region.
In my opinion better device to utilise gain from nonlinearity od ferromagnetic material would be a flyback converter.
With a large ratio of primary to secondary, like 1:100 it would take a very small magnetizing current to magnetize ferromagnetic core with a few primary turns (without BEMF from secondary during  magnetization part "ON") , and during "OFF" time collapsing magnetic field is acting upon 100 times more windings. Some air gap in the magnetic path of such flyback would be beneficial to increase energy level stored in magnetic field.
Cheers.
Pix
ramset
I see it's quieter at ( less interruptions /FE noise / tonnage??)
And no sneakers needed to run back and forth to read the page ( do to oversized images posted repeatedly in this thread)
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/509697-holcomb-energy-systems-the-holy-grail-may-have-arrived#post509831
Thanks Grandma
r2fpl
If the Holcomb devices work, it must use a power source such as some fuel. There's no other way. No spinning the magnetic field will do anything.
It is only needed to perform the conversion of energy into other energy. A possible version is iron conversion. He also writes about it.
The magnetic field is only needed for the conversion process and is frequency and power dependent for iron.
This is similar to NMR but only for a given process.
Quote from: r2fpl on March 27, 2022, 10:32:30 AM
https://overunity.com/13165/the-true-tesla-coil/msg554012/#msg554012
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP#
Method and apparatus for converting energy from the surroundings into electric energy.
The invention relates to a method for converting .kinetic energy present in the surroundings into electric energy, in which the kinetic energy is converted by means of magnetic flux variations, brought about in or near an electrical conductor, into electric energy in said electrical conductor. Preferably use is made of kinetic energy, which is present in the surroundings in the form of magnetic energy to generate an electromotive force in the electrical conductor.
The invention also relates to an apparatus for converting kinetic energy present in the surroundings into electric energy, which apparatus is provided with an electrical conductor and means for generating magnetic flux variations in or near an electrical conductor, for generating from the kinetic energy present in the surroundings, into electric energy in the electrical conductor. Preferably, from the kinetic energy, present in the surroundings in the form of magnetic energy, an electromotive force is generated in the electrical conductor.
It is known from the physics of particles that gravitons can convert, inter alia, into photons as they pass through space and matter, as a result of which energy is released. These photons occur both in space and in matter and they represent energy, i.e. kinetic energy. Said photons, inter alia, determine the mutual interaction between electrons, and said electrons can b.oth emit and receive photons. As is known also electron spin moments can be directed in a material by the technique of permanent magnetization, as a result of which kinetic particles, among which photons, released also start to flow through the material in a direction, the so-called magnetization direction. The disturbed energetic balance is restored by a field of kinetic particles in the surroundings of the material directed along the known magnetic field lines outside the material.
Likewise in the case of an electron current through an electrical conductor, a flow of kinetic particles flowing along the magnetic lines of force will likewise be produced outside or around the conductor. By winding the electrical conductor into the form of a coil , a flow of particles can likewise be produced which is comparable to the flow of particles in the case of a permanent magnet and so a concentrated field of particles is obtained.   In the method and apparatus of present invention use is made of abovementioned phenomenon, in which<'> the external field of kinetic particles is influenced such that the energy thereof is absorbed in an electrical conductor. This absorption of kinetic particles energy, among which also heat, can be obtained by means of the application of a suitable stationary magnetic field and/or a variable magnetic field.
For example, by varying or pulsing the electron current through the electrical conductor in the current direction at high frequency, the photon field, which compensates for the balance around the conductor, becomes active to such an extent that photons are absorbed from the surroundings into the electrons in the electrical conductor. As a result, energy is taken up from said surroundings into said electron current.
https://www-maschinenbau--wissen-de.translate.goog/skript3/werkstofftechnik/metall/3-kristallstruktur?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Holcomb pulsing controller process ?
wmbr
OCWL
