Jimboot
Quote from: ramset on December 04, 2022, 05:05:57 PM
Got a bit of positive feedback on some product delivered to actual end user !
Will try to find out a bit more detail!
That would be interesting Chet!
kolbacict
Quote from: bistander on December 04, 2022, 02:25:17 PM
Please show us what you're talking about. Are you able to video the CRT effects in that excited stator?
I will definitely show you.
Can't find the right size.
The photo was a single-phase stator from the refrigerator. It doesn't fit.
If you knew my life...
Only that the bombs are not falling yet ... :)
ramset
Jim
Unfortunately an anonymous claim from ....( cannot qualify at this time ..working on that ATM
Anonymous claims in our world ( the FE over-unity world)
Are really not where this topic should be pointing ( do to horrific past history of such claims!
Here IMO caloric measurements should be used with side by side testing using simple water calorimetry ..a scientific standard ! ...
Honestly when we get some happy end user (unattached to claimant)... it will really be nice !
For clarity I write these things only because I hear of soo many persons trying to buy or purchase ,
And no "buyers" reporting a result publicly  ..( behind the scenes there are confusing stories from would be buyer's or customers !
Heat some water ...caloric storage in water is a known science ( energy in vrs temp rise ...for most of modern scientific history!
Respectfully
Chet K
PS
Perhaps above is misleading.. it might be that would be buyers are put in contact with happy customers after some vetting process?
IMO such a tech needs to get out "sooner the better"
What is happening in Europe ATM is just tip of the ice berg !
So yes it's a desperate time !
Thanks Grandma
bistander
Quote from: kolbacict on December 05, 2022, 01:24:38 AM
Hi kolbacict,
Okay. You know that to get the RMF (Rotating Magnetic Field) you need 3-phase power on a stator wound for 3-phase.
Other note: if you go by handle Chief Kolbacict on the OUR forum, that motor in question with 2 wires is most likely a PMDC motor. Rotation direction dependent on polarity. No load RPM directly proportional to applied voltage. Torque directly proportional to current. For tape reel drive often armature construction has no iron, giving very low moment of inertia, quick speed changing, smooth rotation without cogging. Some models used what was referred to as printed circuit armature but was actually layers of stamped thin copper sheets separated by fiber sheets and welded tips. Nice small motors. Fairly efficient. No core loss. But brush friction and resistance loss. Good high speed and regulation. Poor thermally and not overload tolerant (for long). Make nice generator, self excited, but needing external regulation (inverter opposed to field control, like an alternator has). Looks like a tacho attached which is common for tape drive motors.
bi
SolarLab
 4-Channel MOSFET board with optional Driver, Screw Connector and Heat-Sinks
These are - Turnkey - populated, soldered, ready to go modules.
Designed by Azduino by Spence Konde in United States of America
https://www.tindie.com/products/drazzy/4-channel-mosfet-board-with-optional-driver/#product-description
Disclaimer - I have nothing what so ever to do with Spence Konde or his business; this is
nothing more than a purchasing users observation. Also, I found Spence a very good fellow
to work with throught the purchasing process.
SL
Update - added MOSFET Data to PDF
