0 Members and 114 Guests are viewing this topic.
Ufopolitics
Quote from: pmgr on March 26, 2022, 11:30:07 PM
@partzman et al,
The inner part is a rotor consisting of 16 poles.
The outer part is also a rotor consisting of 16 poles.
The poles of inner and outer rotor are aligned and reinforcing when biased.
These 16 poles are grouped in 4 groups of each 4 neighboring poles,
leading to an overall rotor pattern of 4 magnetic poles (N-S-N-S)
The center part is the stator with 36 slots. Since we have 4 poles on the rotors,
we have 4 groups for each phase on the stator.
Each group has 3 coils in series. The coils are lapped with a span of 6, so e.g. 1-7.
This is the slot assignment for the rotor.
x-y means a single coil sitting in slot x (left side of coil) and slot y (right side of coil)
(x1-y1,x2-y2,x3-y3) means these three coils are wired in series
Phase 1 group 1: (  1-7,    2-8,     3-9  ) facing N pole of rotor
Phase 1 group 2: (10-16, 11-17, 12-18) facing S pole of rotor
Phase 1 group 3: (19-25, 20-26, 21-27) facing S pole of rotor
Phase 1 group 4: (28-34, 29-35, 30-36) facing N pole of rotor
Phase 2 group 1: (13-19, 14-20, 15-21) facing N pole of rotor
Phase 2 group 2: (22-28, 23-29, 24-30) facing S pole of rotor
Phase 2 group 3: (31-1  , 32-2  , 33-3  ) facing N pole of rotor
Phase 2 group 4: ( 4-10,    5-11,   6-12) facing S pole of rotor
Phase 3 group 1: (25-31, 26-32, 27-33) facing N pole of rotor
Phase 3 group 2: (34-4,   35-5,   36-6  ) facing S pole of rotor
Phase 3 group 3: (  7-13,   8-14,  9-15) facing N pole of rotor
Phase 3 group 4: (16-22, 17-23, 18-24) facing S pole of rotor
For each phase, coils in groups are wired in series as group1 - group2 + group3 - group4 (N-S-N-S)
Hi PmgR,
You were right in the first part, until you wrote the bold sentence by me: "Each Group has three coils in series"...and so, from there on, the explanation  is not right.
That is incorrect, each group has Four (4) Coils in series.
This is all about understanding Spatial Geometry...in this setups...
We do not need to be "required" to use any specific configuration of number of poles...as long as we can combine Pairs in series of single coils all along the 360º circumference.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
r2fpl
lancaIV: Patents do not confirm that this is true, and such a device only works that way. In the future, if someone does it, maybe.
You know how many patents of this type are there, right. How many real devices are there?
One thing is for sure, it must be a conversion.
Ufopolitics
Quote from: r2fpl on March 27, 2022, 10:32:30 AM
If the Holcomb devices work, it must use a power source such as some fuel. There's no other way. No spinning the magnetic field will do anything.
It is only needed to perform the conversion of energy into other energy. A possible version is iron conversion. He also writes about it.
The magnetic field is only needed for the conversion process and is frequency and power dependent for iron.
This is similar to NMR but only for a given process.
You are dead wrong pal...period.
No "Fuel" is used here, except for the "Fuel" of DC Magnetic Field GHOSTS DANCING IN A CIRCULAR MOTION... ;D
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: ramset on March 27, 2022, 10:09:49 AM
I see it's quieter at ( less interruptions /FE noise / tonnage??)
And no sneakers needed to run back and forth to read the page ( do to oversized images posted repeatedly in this thread)
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/509697-holcomb-energy-systems-the-holy-grail-may-have-arrived#post509831
Hello  Chet,
The fact pages stretch and you need sneakers to run back and forth...is not due just to oversized images...now, on this page we still have to run quarter mile to reach right end...
It is the copied and pasted links here, by Ianca, with a specific longer format that our editor can not correct automatically...
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: r2fpl on March 27, 2022, 06:07:36 AM
https://holcombenergysystems.com/wp-content/uploads/2020/03/Technical-Summary.pdf
...In comparison, the HES alignst the domains and   relaxes the alignment, and re-aligns and
relaxes continuously every 4   milliseconds (250Hz) . Therefore we get the magnification   effect 250 times per   second.
The key = relaxes
Wrong again...
The "key" is not any relaxation...anywhere.
Every Pair of Coils from each Group are REVERSING POLARIZATION on a timely bases.
In a Four Group set, Two Pairs of Coils are reversing polarity simultaneously...
In a Six Group of Coils Three Pairs are reversing polarity at unison.
There is absolutely NO COILS COLLAPSING TO ZERO -IN STATIONARY ROTORS- AT ANY POINT OF THE ENTIRE OPERATION HERE!!!
So no "relaxation" but reversal of domains at molecular steel levels.
At the same token, these constant reversals do not allow steel cores to saturate ever...magnetically.
It keeps constantly "cleaning domains arrangement" from only one directional orientation to develop at the millisecond level of time.
Ufopolitics
―Leonardo da Vinci
