rakarskiy
Dear "experts in the field of electrical machines": hidden, secret, explicit and other (...) that is in the service of the system!
Answer two questions.
1. How is the mechanical power (Pk=Fv) applied to the generator shaft converted into electrical power (Pe=IU), which is measured at the generator terminals?
2. How is EMF induced in the generator conductor, which is laid in the generator groove? What is needed is not figurative reasoning, but exact processes with a mathematical description of the entire period of the sinusoidal EMF signal.
This will be enough. If you cannot, then complain to the sex reform league that you were interrogated by me about your professional suitability, evaluate something, conduct examinations in the field of electromagnetic-mechanical or solid-state machines.
Sincerely.
SolarLab
Quote from: bistander on December 10, 2022, 12:43:38 PM
"You claim this creates a GENERATOR that will OUTPUT up to 5 (five) times the POWER
that is INPUT into the motor."
Exactly where have you seen me claim that. Reread my posts on the subject. What I've said was ". No doubt been done thousands of times by engineers and technicians. Never heard of anomalous energy appearing. I don't understand how Holcomb does it, so I doubt it happens." See post 1531.
And similarly on previous posts about the stalled induction or synchronous machines, no excess energy appears.
Been my point/question all along: What makes Holcomb's device different? Nothing which I can see.
bi
OK, thanks for clearing that up!
I thought the same at first - can't be done - but a little study and analysis changed my mind!  ;)
Have a good day...
bistander
Hi SL,
QuoteI do have a bit of scientific and engineering knowledge, but the "logic" and "method"
of simply locking the rotor of a motor turns it into a generator, still escapes me.
First off, physically a motor or generator is the same machine. How it is used typically defines which it is called. And the common definition of electric generator is device which converts mechanical energy into electrical energy. Since a device at stall (or locked rotor) has zero mechanical energy input (zero RPM), it would not be considered a functioning generator.
Like I mentioned, with induction motors, engineers and technicians often use no-load tests and locked-rotor tests to characterize the machine. Such methods were taught and used when I was involved with academa and industry. And in fact, every motor starts operation from zero RPM or at stall. Many polyphase induction motors are "turned on", or started from stall by simply slamming it across the mains. So at that instant, just before rotation commences, there is a rotating magnetic field with stationary windings on the rotor, and no excess or unexpected energy, ever, over millions of occurrences. This leads me to believe that Holcomb is mistaken or is hiding something.
bi
listener192
Quote from: SolarLab on December 10, 2022, 12:28:00 PM
Some of the patent issues were covered early on in the OUR thread...
SolarLab,
I think you are refering to this line item in one of your posts
EXCEPTIONS AND LIMITATIONS TO PATENT RIGHTS: PRIVATE AND/OR NON-COMMERCIAL USE[/size]
However, the attachment was only for WIPO patents not U.S. patents.
Does anybody know what the limits/liabilites are with U.S. patent replications?
L192
rakarskiy
bi
I do not rely on Holcomb's data, but on the experiments that were carried out with my participation (according to my recommendations).
https://rakatskiy.blogspot.com/2022/06/static-electromagnetic-transducer.html
