rakarskiy
Quote from: SolarLab on December 10, 2022, 01:44:33 PM
Hi Rakarskiy,
Quick questions - (1) Your ROTOR has a metal core, correct (maybe obvious but maybe not) and - (2) Do you know
the type of metal used in the Stator and Rotor (electrical steel, also known as motor steel)?
Thanks,  SL
Youv'e probably posted all the information somewhere but I'm too lazy to look right now!
Hello!
The experiment used a purchased Chinese single-phase 5 kW generator. I don't know the manufacturer's name. It was dismantled, its rotor and stator were used for the experiment. The stator is inserted in such a way that there is no contact between the rotor iron and the stator iron. It's hard to tell what brand it is. I chewed through all the details in the material, including the labyrinths of measurements. If everything is confirmed as I understood, then in the book, the description will be more detailed. In any case, I came to that logical understanding of what still happens in generators, even ordinary ones. Probably right are those members of the forum who are sure that the fields rotate - that rotation, only rotation occurs in a constant field (flow), a variable phase will not provide this. But switching electromagnets will provide this freely. In any case, I came to the conclusion that the magnetic lines do not cross the phase wires, they form a window vortex, in the middle of which an EMF is induced.
Sincerely.
listener192
Quote from: rakarskiy on December 10, 2022, 01:14:41 PM
I do not rely on Holcomb's data, but on the experiments that were carried out with my participation (according to my recommendations).
https://rakatskiy.blogspot.com/2022/06/static-electromagnetic-transducer.html
Hi Rakarskiy,
I looked at your experiment. Those plug in energy meters do not read correctly when fed with line voltages below 100V, so at 39V (under load) I would think your reading cannot be relied upon.
L192
bistander
Quote from: SolarLab on December 10, 2022, 09:35:19 PM
Yep, I can see wut yur sayin ...
For clarification:
QuoteWhat Is Imputed Value?
Imputed value, also known as estimated imputation, is an assumed value given to an item when the actual value is not known or available. Imputed values are a logical or implicit value for an item or time set, wherein a "true" value has yet to be ascertained.
https://www.investopedia.com/
Google "imputed vs input"
bi
rakarskiy
Quote from: listener192 on December 11, 2022, 07:16:23 AM
Hi Rakarskiy,
L192
There is information about this in the material. Only besides wattmeters, there were measurements with voltmeters. In different circuits at idle and under load. Don't be hasty with conclusions.
kolbacict
As Giordano Bruno said.
It spins however. :)
While very preliminary.
Very poor beam focusing and all that...
