SolarLab
Quote from: rakarskiy on December 11, 2022, 06:42:18 AM
Hello!
The experiment used a purchased Chinese single-phase 5 kW generator. I don't know the manufacturer's name. It was dismantled, its rotor and stator were used for the experiment. The stator is inserted in such a way that there is no contact between the rotor iron and the stator iron. It's hard to tell what brand it is. I chewed through all the details in the material, including the labyrinths of measurements. If everything is confirmed as I understood, then in the book, the description will be more detailed. In any case, I came to that logical understanding of what still happens in generators, even ordinary ones. Probably right are those members of the forum who are sure that the fields rotate - that rotation, only rotation occurs in a constant field (flow), a variable phase will not provide this. But switching electromagnets will provide this freely. In any case, I came to the conclusion that the magnetic lines do not cross the phase wires, they form a window vortex, in the middle of which an EMF is induced.
Sincerely.
Hi Rakarskiy,
Thanks very much for the information.
Another question - Can you measure the Gauss (Tesla) of the Rotor - Stator easily at various amps?
A Gauss/Tesla Meter like the TM-197 might work to measure "B" with the thin probe (use PC USB
to record a few thousand measurements per current step).
    [[If you need a Tenmars TM-197 or Latnex MF-30K - PM me...]]
Regards,
SL
rakarskiy
Hi SolarLab!
Unfortunately, nothing will work out, the guy who conducted the experiment has good opportunities and has a device for measuring magnetic dependence. Since the summer I have not contacted him (war). By the way, measuring the magnitude of the magnetic field in the gap does not give a complete picture, it can only be calculated from the inverse (EMF in phase at idle). I simply cannot post everything that is not mine (many people share information with me, but this is their information and I do not have the right to post everything). Photographs show deep research.
Everything works great, this is for the skeptics.
But now I may have found the component from which to build on.
SolarLab
Hi Rakarskiy,
Thanks and I can certainly appreciate the "confidentiality" - it's a very good business and personal practice to always
consider it in the scheme of things.
Good luck and take care - hopefully the politics (war) will quickly sort itself out.
SL
kolbacict
Уважаемый Ракарский,смотрите что мне тут сегодня подкинули...
The other ones can too... :)
Cadman
Quote from: rakarskiy on December 11, 2022, 02:48:40 AM
I do not understand the role of provocateurs of the system? Holcomb's machines are under the control of the US government. If he received patents and agreed to the restrictions and conditions, then the system is working. The question is whether this system is necessary for energy companies?
everything becomes clearer for me, I even have answers to those questions that had previously baffled me.
This is why the inline generators are being allowed by the government, or should I say the people that control the government. The reason is the power companies will be allowed to use this tech to increase their profits. They will install it in their distribution stations ahead of the consumer. Their generation costs will fall drastically, but we, the end user, will still pay the higher prices.
If you are wealthy, you may be able to have one at your residence or business too. But only if you can afford it. I expect a batch of legislation or regulation laws will be created to throw obstacles into the path of private use too.
Of course this is just my opinion.
