Ufopolitics
THE ONLY START UP "SETTINGS" ON THIS TYPE OF GENERATORS:
The only requirement whenever starting these type of generators -from cold- (after long periods of inactivity)- is to start first at a low "idle" speed...to start "waking up" all randomly set steel alignments...which set them in the reversal axis spatial positioning, ready for higher speeds...
Something similar to what we need to do whenever starting an ICE farting machine...idle at low speed to get the right temperatures on  metals, plus allow oil pump to grease all rotating components...
except that the time for these generators in only a  couple of minutes.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pmgr
Quote from: Ufopolitics on March 27, 2022, 11:07:51 AM
Hi PmgR,
You were right in the first part, until you wrote the bold sentence by me: "Each Group has three coils in series"...and so, from there on, the explanation  is not right.
That is incorrect, each group has Four (4) Coils in series.
This is all about understanding Spatial Geometry...in this setups...
We do not need to be "required" to use any specific configuration of number of poles...as long as we can combine Pairs in series of single coils all along the 360º circumference.
Cheers
Ufopolitics
@Ufopolitics
My write up is correct. I think you probably overlooked the very last line.
For each phase, coils in groups are wired in series as group1 - group2 + group3 - group4 (N-S-N-S)
For each phase, each group 1-4 is in series as well. So total of 12 coils per phase in series. Each group 1-4 of course in proper polarity to match the rotors (N-S-N-S) and have the induction effects add up instead of cancel out.
pix
pix
Quote from: ramset on March 27, 2022, 10:09:49 AM
I see it's quieter at ( less interruptions /FE noise / tonnage??)
And no sneakers needed to run back and forth to read the page ( do to oversized images posted repeatedly in this thread)
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/509697-holcomb-energy-systems-the-holy-grail-may-have-arrived#post509831
Please send lancaIV to  addiction rehab. ;D
Guy is on something.
pix
Quote from: Ufopolitics on March 27, 2022, 11:36:39 AM
Wrong again...
The "key" is not any relaxation...anywhere.
Every Pair of Coils from each Group are REVERSING POLARIZATION on a timely bases.
In a Four Group set, Two Pairs of Coils are reversing polarity simultaneously...
In a Six Group of Coils Three Pairs are reversing polarity at unison.
There is absolutely NO COILS COLLAPSING TO ZERO -IN STATIONARY ROTORS- AT ANY POINT OF THE ENTIRE OPERATION HERE!!!
So no "relaxation" but reversal of domains at molecular steel levels.
At the same token, these constant reversals do not allow steel cores to saturate ever...magnetically.
It keeps constantly "cleaning domains arrangement" from only one directional orientation to develop at the millisecond level of time.
Ufopolitics
1. Field reversal means going through ZERO. That means field collapsing. And yes- ferromagnetic material domains changing it's orientation  :)
2. Please explain mechanismo of gain.
Cheers,
Pix
