0 Members and 58 Guests are viewing this topic.
Ufopolitics
Quote from: pix on March 27, 2022, 12:18:18 PM
1. Field reversal means going through ZERO. That means field collapsing. And yes- ferromagnetic material domains changing it's orientation  :)
2. Please explain mechanismo of gain.
Cheers,
Pix
1- If we are talking about fractions of miliseconds taken in the reversal time, from positive to negative as neg to pos...then can you figure out the timing that it takes to "pass" by the zero line?
Answer: The time passing by zero line is such small fraction of time, that in our Scientific Community, we call it to  "disregard it"... ;D
2- Sure, if you can imagine FIRST, the rotation of a massless, weightless, entity which can go through steel and copper in zero time, and cut it like a knife does to air...without absolutely any obstruction...
Versus moving 50 pounds of steel and copper to do just the same exact, operation...
Thing here is that that "ENTITY" called Magnetic Field can reach speeds that never any mass body could ever reach...
Can you analyze and compare?
Good enough?
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
r2fpl
Quote from: Ufopolitics on March 27, 2022, 11:12:33 AM
You are dead wrong pal...period.
No "Fuel" is used here, except for the "Fuel" of DC Magnetic Field GHOSTS DANCING IN A CIRCULAR MOTION... ;D
Ufopolitics
Maybe so, but you have nothing but your words.
....The "key" is not any relaxation...anywhere....   It depends on what we mean by relaxation.
I have worked with Pierre.
Ufopolitics
Quote from: r2fpl on March 27, 2022, 01:13:15 PM
Please allow me to Laugh Out Loud... ;D ...or ROTFLMAO
Quote from: r2fpl on March 27, 2022, 01:13:15 PMI have worked with Pierre.
Great!!!...so  maybe you could reveal "his secrets" here....hahahahahahahahaha
Oh, this was funny!! ;D
―Leonardo da Vinci
r2fpl
Ufopolitics:
You're a funny guy.
You have been standing in the place for a long time. Don't move because it may fall.
You probably believe in UFOs and Santa Claus.
Uhahahaha
pix
Quote from: Ufopolitics on March 27, 2022, 12:38:17 PM
Good enough?
Cheers
Ufopolitics
1. "Disregard it because you think it is happening a short time ".  :D  it is not working like that. What is enough of short time to disregard it, in your opinion?? Milisecond? Microsecond? I think you are joking.  Also, typical Si-based laminated ferromagnetic steel do not like  quick pulsed signals, typical AC motor stator and rotor are done from "transformer steel" laminations and they are working good  at 50-60Hz. Increase in frequency increases eddy current losses and produces a heat, and abrupt changes are chocked because solenoids do not like abrupt changes of current. In Holcomb device I see regular stator from 3 phase motor, made from laminated  silocone based "transformer steel".
2....and you have a transformer  :D . Flipping domains by "massless, weightless entity". No mater how fast you are going to do this flipping, Lenz law applies plus core losses.
The same situation happens when you put slip ring AC motor with wound rotor in "locked rotor" mode of operation. You have also "massless, weightless entity cutting through the steel and copper", no physical rotation. And it is eqiuvalent of transformer operation, nobody claimed any OU there  ;)
Cheers,
Pix
