Jimboot
Quote from: SolarLab on December 26, 2022, 06:27:51 PM
A belated Merry Christmas Jimboot,
Maybe the info on page 7, or so, might be of interest (turn count ?).
From some old notes re: the patent...
Happy New Year Mate!
SL
cheers mate! I think I'll use the assistance of chatgpt to write the arduinao code. It's already written a bunch of python scripts for me for another project.
SolarLab
Quote from: bistander on December 27, 2022, 03:36:39 PM
Hi SL,
I clipped, yes. But not to fool or deceive anyone. And using the quote feature, the reader simply needs to click to see your original message complete. I did it to shorten my reply and reference the specific subject I was about address, ie. that beginning at [0089]. You had truncated* the original to the point of eliminating the main subject of that section, which is the unipole rotor. And that is a totally ridiculous idea and certainly not helpful or of any value, especially to a LinGen design.
The point of my post was that the patent application is not helpful, as you said. For the record, by law, a patent must be non-obvious, new, and useful. I await to see anything useful to come from trash like that document.
So please show me what is helpful. Or insult me further. And those skilled in science and technology can easily see that the author of that patent application is functionally ignorant on the subject. The things which you call petty are indicators that the author doesn't know what he's talking about. There are numerous examples in that and other documents from Holcomb.
bi
* You did provide link to the original document. Thanks. It had been awhile since I'd read it. It is truly remarkable, in a bad way.
Yea, OK - right!    ---  >> $$$  - you're welcome... Merry Christmas
listener192
Regarding the patent statement about geometric isolation..
With one coil edge in an inner stator slot and the other coil edge  in an outer stator slot, each coil edge being in seperate magnetic circuits, via the inner and outer rotors. So lets assume the rotor induction (either by flux movement, or flux linkage), results in a current flowing in the loop of the coil.
Lenz applies to the electron charge in each coil edge, irrespective of seperate magnetic circuits initiating induction, as Lenz is essentially an action of charge against charge (with magnetic flux as an intermediary).
L192
kolbacict
Can you make your Lenz to change periodic the magnetic permeability of rotor material(secondary ) ?
Exciting in this way, parametric oscillations in the secondary winding?
So that Lenz does not interfere with us, but helps?
listener192
Quote from: kolbacict on December 28, 2022, 08:31:40 AM
For each electron charge moved by induction in a wire, the same moving electron charge produces its own magnetic field which in turn opposes the movement of the electron charge. You cannot separate these actions.
L192
