0 Members and 18 Guests are viewing this topic.
SolarLab
Quote from: bistander on January 04, 2023, 05:17:35 PM
Hi SL,
Please provide a link or pathway to the website which doesn't require membership in faceclub.
Thanks.
bi
Link posted by mistake - disregard. Sorry.   :(
SL
rakarskiy
Quote from: bistander on January 04, 2023, 05:08:40 PM
Hi rakarskiy,
Motor and generator designers are able to accomplish the task all the time using the theories, laws and principles which I have referenced. Perhaps the difficulty is with you, not the technology or knowledge base, or perhaps it is just a communication breakdown and I fail to realize what you are talking about. Does seen odd that you're writing a book about something that you claim you can not do. But I think you are among us that practice free speech, so good luck.
bi
I'm talking about this slide, which explains the induction of EMF in the generator phase:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg572484/#msg572484
All this is remarkable for a conductor in a magnetic flux, where the lines of force intersect (have physical contact) the surface of the conductor, in which the EMF is induced.
The strength of the current is a different process, which is already calculated according to Ohm's Law. Or your electricity is not divided into voltage and current.
There is no magnetic field from the core in the generator slot, the magnetic flux is all inside. If you apply voltage and current to the generator windings, it will induce a magnetic field in the core, but on the contrary, this does not work on the slide in question.
But I have already gotten to the bottom of why oscillations and a shift between the fields from excitation and phase are needed.
bistander
Quote from: rakarskiy on January 05, 2023, 07:18:23 AM
Hi rakarskiy,
Is your referenced slide correct? See image below from:
https://tinyurl.com/3cj4f7bp
bi
rakarskiy
Quote from: bistander on January 05, 2023, 11:49:36 AM
Hi rakarskiy,
bi
I mean this slide:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/188837/image//
Very interesting article!
But many of the provisions that are set out here cannot be confirmed by a description and a detailed mechanism for the relationship of the sequence of actions.
If we consider the complete circuit of electrical oscillation (voltage / current), for example between inductance and capacitance, then there is no phase shift of voltage and current. I established this a long time ago (even proved it on the fingers of some doubters).
If in a transformer (in a traditional one), when the windings are wound one on top of the other, the transfer occurs by the method of interturn mutual induction, if on different rods - by the Faraday induction method. By the way, how does this happen until the mechanism is established (Faraday induction).
This is a very interesting and big topic, I will present my vision in the book. To confirm, I will conduct a series of simple experiments so that everyone can repeat.
By the way, I already have a long history of how a transformer works and how EMF is induced and current is generated.
The fact that Voltage (vortex electric field) turns into current strength (vortex magnetic field) can be emphasized from this material of mine:
https://rakatskiy.blogspot.com/p/ampere-force.html
