rakarskiy
I conducted an interesting experiment, which is closer to confirming my theory, about the causes of the occurrence of EMF in the generator stator slot, as well as in the transformer window itself. Thus, I will add something that is not in Faraday's law of electromagnetic induction - a step-by-step mechanism. Something that has not yet been found, but because of the "oblique hastily carried out."
Along the way, I conducted an experiment to work out the pulse excitation system of my generator, with a recuperative system. The results are on the slide.
A coil wound on a 2.37mH 0.9 ohm ring core is pulsed through a half-bridge, the reverse pulse is sent back to the capacitor to start the next pulse.
From the source 0.5A, (in the pulse 1A, due to the duty cycle of the pulses 50%)
At the peak of the pulse on the coil 2.37-2.5A.
floodrod
Quote from: bistander on January 07, 2023, 01:11:50 AM
Hi floodrod,
I believe that you refer to impedance in the circuit. The pdf and graphic which I attached in recent reply to Ufo explains this. At lower frequencies and sinusoid waveform, Ohm's Law and Kirchhoff's rules apply using Z in place of R and phasors for V and I. Also PF, power factor is relevant. The math becomes complex, but circuit analysis follows the same principles.
bi
Cool...  I can't argue that.  My point was wattage a coil will pull powered with AC can not be solved with the standard V/I/R formulas alone. If a coil measures 8 Ohms and I send 8V AC into it, amperage will not always be 1 amp.  It depends how much back EMF the coil itself is producing that impedes the incoming power.
My belief is the math and formulas are predictions what will happen in a given setup. I am much less interested in the formulas than actually understanding the forces at play and the chain of reactions (and why)..   I know the formulas are accurate, but if I want to break the laws, I have to figure out what exactly is happening in that coil step by step then attempt to manipulate the chain of events to produce a different outcome.
Anyway, thanks for the graphic and explaination.
Ufopolitics
Quote from: kolbacict on January 06, 2023, 05:56:24 AM
Have you noticed what is really happening inside the stator near the iron pole pieces?
This is when the stator is powered by a three-phase current from the frequency converter, in my case.
I think Holcomb's commutator is also something similar.
What does the electron beam show, because, unlike a squirrel-cage rotor, it has no inertia.
How the beam is smeared, how much dirt, higher harmonics, intermodulations and other things are there, you, the specialists, know better. But these are our losses. I think this should be gotten rid of.
When used as a conventional induction motor, the rotor converts it quite efficiently into mechanical rotation.For rotor this harmonics don't big mentions.But I do not know how it will show itself in our case. If not for the beam, we would never know what is happening in reality.
We think that everything is smooth and smooth there.
Hello Kolbacict,
I really enjoyed what you did with the CRT Tube inside AC Stator on your previous test video!!
I have been looking for a while for a long tube CRT like the one you have there, it is a very clear explanation of what is going on inside empty stator air housing for rotor (or for a static rotor, to be used as Output)...however, all that noise, dirt, higher harmonics, etc,etc...are there because there is no Rotor inside with a Field to interact with Stator.
Once there is a Rotor inside the Stator, plus, there is also a secondary field induced or excited on, then all flux lines up, aligns and becomes smoother and cleaner.
I have done a similar test with the Alternator Stator pulsed by the 3 FET's circuit, while readiong it on a 4 channel scope...and whenever I do not apply the rotor power the magnetic field, the 3 sines are very dirty, with also higher harmonics, exactly as you have written.
But there is a Test, that I would like you to do, since you got everything there...as I never was able to get such type of CRT long tube.
So, please, wrap a coil of wire around the glass tube, basically where the e-beam is rotating on the outer edge of glass, and since this coil would be set horizontally related to Stator Coils, it should NOT Induce any currents. So the Stator will only serve to rotate the e-beam.
Set tube and coil inside stator, then take a reading of the coil you wrapped around CRT Tube, while applying your 3 phase from inverter to Stator.
Please let Us know what is your reading, plus if you could measure it as well, or even better, see it on a scope.
This Coil output should be energized just by the e-beam rotation around glass tube, and it should not be a lot of power...since this is not the "perfect" setup...but it should show an energy output.
Thanks
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
stivep
Quote from: kolbacict on January 03, 2023, 09:59:41 AM
https://youtu.be/OGkvfH44dr0
It is better to put a CRT in a stator only its screen, where there is no metal inside the CRT.
One note, in the middle of the CRT shows much less field than near the stator iron. :)
Quote from: Ufopolitics on January 07, 2023, 09:55:42 AM
https://www.youtube.com/watch?v=SiZ-mak4h4s
____________________________________________________________________
this addition,  is just for ... a general curiosity
https://www.youtube.com/watch?v=wqrGHeuxUvI
Wesley
rakarskiy
By the way, you didn't think that in the Holcomb generator, as well as in the synchronous mechanical electric generator, the core where the wires are laid in the groove is in the maximum saturation mode. It is not a variable field that rotates, but a constant one.
This is another tip that for some reason no one paid attention to.
