0 Members and 58 Guests are viewing this topic.
Ufopolitics
Hello Ramset et Al,
Here is the simple schematic for test connections and structure...for sake of simplicity to understand it, I did not add any mountings nor base stands.
It should be understood that second flat type commutator is fixed to a base, as also the small motor.
Please, make sure you wrap your rotor with some tape which holds high temperatures, as to make it pretty stock/locked inside Stator, so when you load output it will not try to spin lose!!
Brushed Symmetrical Motors Armatures are wound by series coils in a close loop with a derivation to each commutator element solder contact...So, +/- Brushes divides the whole armature in two (for two brushed motors) so, it divides Rotor in a perfect Half with N/S Magnetic Field set at 180 degrees apart.
So, if we just rotate the feeding +/- brushes to the armature static coils through this remote setup with the small motor on the right, we will be spinning just the DC Magnetic Field of the Rotor within the stator...
Your Stator Coils, connected in series would be your output
Your Rotor would be your Input at the Continuous Slip Ring Brushes contact.
These I/O could be measured in a Two Channel Scope.
The Input for the small motor needs to be isolated from a second PSU, small power, maybe 5V and max 2A...
I used a Flat type commutator as the fixed one where brushes spin, since it is more secure at higher speeds,as it will not loosen contacts by centrifugal forces pushing brushes away from contacts...
You could also "beef up" your Stator with thicker wire and more turns...for higher output levels...or get a full 360º wound stator from another AC Induction motor of same inner diameter as your rotor...so there will not be a too wide air gap...
As you could do a lot more of improvements as you like...or adding an AC Cap to Input to smooth the waves...or adding a Diode Bridge to run DC Output to store it in Supercaps...
It would be good to add reflective tape to your small motor shaft, to read the RPM's you are turning your Magnetic Field...
Make sure you keep reading the temperature of all coils, Input-Output...do not get "excited" by the results and forget that this is NOT a Real Generator... ;D
It is a very "interesting test"... :)
You will have fun, when loading your output... ;D
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
―Leonardo da Vinci
pix
Quote from: Ufopolitics on March 28, 2022, 11:01:10 AM
Of course, you wanted to make sure if it works or not...I agree it is the only way to know for sure...
Unfortunately it didn't work...but, this is the way we can ever get to know...
And thanks, but it is not "exactly" how Holcomb works the test I suggested above...same principle though.
Cheers
Ufopolitics
Actually it worked.
The part when I tested 3 phase motor to work as asynchronous generator was a success.
Everyone could make an cheap emergency generator out of lawn mover engine and regular 3 phase squirrel cage motor  with capacitors. Don't even needs to be spinned above nominal speed.
Efficiency of such ansynchronous generator is 75-85%, better than some regular generators. The only regulation it needs is to increase capacity if load increases.
Converting AC motor to PM generator is not very efficient setup to run ac inductive loads. Yes , I got nice voltages: 153V at 1200rpm up to 200V at 2000 rpm per phase. Didn't tested higher rpm's.
Such PM generator is best to spin well above nominal speed and rectify output with 3 phase rectifier. Then it is  very efficient machine.
Cheers,
Pix
I have to say as soon as they started talking about "reducing your consumption by half" and claiming the discovery to be literally the permeability of iron, red flags started going up.
Any device with that much excess energy can easily be looped back, the "inline" aspect of it makes it shady as hell.
