onepower
Dog-one
QuoteWhat is the gain function?  The formula?  What does this formula most closely match up to?  Are there other methods to utilize this same gain function?
Since energy cannot be created or destroyed only transformed the energy gain must be a transformation of some kind.
QuoteLastly, how could we have missed this (even by accident) in all the engineering solutions over the last century?
How did we miss the thousands of other new discoveries being made every day and as we speak?. If you listen to the people actually making all the new discoveries they were trying to learn something new. Thus the ability to learn and educate ourselves must be the way forward.
QuoteIf those questions cannot be satisfactorily answered, then the HES is magic or shall we say, an illusion with all the connotations associated with such a trick.
"Any sufficiently advanced technology is indistinguishable from magic"- Arthur C. Clarke
AC
rakarskiy
I want to clarify a little:
Working principle (by generating electromagnetic field, electrical energy) Electromechanical synchronous generator and solid state electromagnetic generator Dr. Holcomb work on the same principle. The difference in the control of the movement of the magnetic field (magnetic flux / fluxes): in the electromechanical power rotation of the rotor in the stator with overcoming the electromagnetic attraction between the rotor and the stator; in Dr. Holcomb's machine, this movement is organized by switching a system of electromagnets.
A feature of the operating state of such machines is a rotating constant magnetic field/flux in saturation mode. The magnetic field of the generator is formed by two sources of the magnetic excitation system and phase currents, which add up to one stream.
Thus, Dr. Holcomb, with his ingenious solution, fulfilled the conditions for the operation of a synchronous electromechanical generator. What I like the most is the "split statement" of physics that a generator is a converter of mechanical energy into electrical energy.
https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEitWqtBG-Xja8dRambo9VSIi0LpMaieLTWuvZyVN_Ybmp1nL0o0cdIfzOqGYyRPhQmmICpT5fIBZ6R-CK0jEGONbJu7ghpuVHWG3nZBtnnZR8LTwNfkgf_o5dlzIsFXe0_2Zua0mex5i7sf8TpfymOBmiaB7qSwH1fCpYpwRrCx9iZ9fv7yrkNe7yTI/s1034/2022-05-26_21233111.jpg
PS
As for the Holcomb model (a generator similar to a powerbank), I expressed my opinion, including based on my parallel study, which has been ongoing for more than a year since 2018 (theory and practice). I found the errors, besides, found the solution and was able to figure out how to do it. At the same time, it immediately became clear how Figuera could do this. It remains to confirm or verify the solution or error. The latest discovery is consistent with all the postulates of the design of electrical machines.
rakarskiy
Quote from: bistander on January 11, 2023, 05:04:05 PM
Hi SL,
If magnetic permeability (u) was an energy gain mechanism as you think, why then is Holcomb's device only 2 to 5 times overunity and not a few thousand?
H is not energy
B is not energy
B= uH
u is not energy gain.
bi
ps. Look it up. A place to start is:. https://en.m.wikipedia.org/wiki/Magnetic_energy
I know how much love you wikipedia, so please search further and learn the facts and truth. I see wikipedia lists Dr. Feynman as a reference. Perhaps he can explain it to you.
https://rakatskiy.blogspot.com/2022/06/magnetization-of-steel-magnetic.html
QuoteFerromagnetic materials, such as iron, cobalt, nickel and their alloys, steel, etc., are widely used in various electrical machines and apparatus to amplify the magnetic field and give it a certain shape.
If a ferromagnetic material is placed in the coil and an electric current is passed through its turns, then under the influence of the magnetic field created by the current, the material is magnetized. This means that the material has its own magnetic field, obtained as a result of the addition of magnetic fields (magnetic moments) of individual atoms.
QuoteMagnetic field strength, also calledmagnetic intensity or magnetic field intensity, the part of the magnetic field in a material that arises from an external current and is not intrinsic to the material itself. It is expressed as the vector H and is measured in units of amperes per metre. The definition of H is H = B/μ − M, where B is the magnetic flux density, a measure of the actual magnetic field within a material considered as a concentration of magnetic field lines, or flux, per unit cross-sectional area; μ is the magnetic permeability; and M is the magnetization. The magnetic field H might be thought of as the magnetic field produced by the flow of current in wires and the magnetic field B as the total magnetic field including also the contribution M made by the magnetic properties of the materials in the field. When a current flows in a wire wrapped on a soft-iron cylinder, the magnetizing field H is quite weak, but the actual average magnetic field (B) within the iron may be thousands of times stronger because B is greatlyenhanced by the alignment of the iron's tiny natural atomic magnets in the direction of the field.
EMF in the generator phase is determined through two formulas: E =Bm*L*V; E = - (Bm*S) / dt; where Bm is already our enhanced magnetic field of the ferro material.
The question is not for physics, she already claims that the ferro material strengthens and creates its own field greater than the excitation. A question for an engineering solution to get more output.
I will even say more (if we do not take into account the mechanical costs of overcoming the magnetic attraction of the rotor / stator in the generator, but only the costs of excitation and phase output), all generators are OU.
SolarLab
Repeating two posts from a few pages back.
Change in Magnetic Field Amplitude VERSUS Change in Magnetic Field Direction
[Note the differences in {signal} output]
Change in Magnetic Field Amplitude: - Positive only or Negative only Pulse (does not cross zero):  {also used in Figuera}
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg572781/#msg572781
Change in Field Direction: - Moving Magnet (N <-> S) or an AC Signal:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg572792/#msg572792
A programmable Controller (Microprocessor, Driver and MOSFET or SiCFET) can be programmed to accomplish either of the above;
and many other exotic combinations of input signals, with any desired time sequences and delays.
Set a variable for the parameters and change these on-the-fly using a display and rotory switch or touch screen for experimenting
and adjusting (tuning). Also, a bit more circuitry and you could adjust the Input Pulse or AC Voltage and Current levels, etc..
SL
SolarLab
 Pick an Electrical Steel with a steep B-H Curve (small H -> large B). See the attached
example (informational only) GO-35ZH135 (Grain Oriented).
Pay careful attention to all the B-H Loop characteristics (B saturation, B remanance, Hc coercivity)
as well as 1. 2. 3. 4. & 5. as shown in the loop below (informational only).
The goal is efficiency with as high as possible output. The "steel" is key with respect to gains
and losses.
Note: Laminations, as per motor fabrication, can cause losses up to ~ 5%
[Laser Cutting vs Stamping apparently helps a bit] (informational only).
SL
Good Luck
