kolbacict
Quote from: rakarskiy on January 12, 2023, 12:46:08 AM
The question is not for physics, she already claims that the ferro material strengthens and creates its own field greater than the excitation. A question for an engineering solution to get more output.
The fact that the field is stronger in iron is clear. But we need not in iron, but in another, secondary winding. Probably when the field enters the iron, it intensifies, and when it exits towards the other winding, it weakens again. Is this the problem?
rakarskiy
SL you just don't understand a little what you're dealing with. Any control scheme is secondary, to the system of a controlled process it is secondary. I'll give you a simple example. The definition of mass is a measure of the inertia of matter. the magnetic field is matter. Imagine that you have a flywheel and you spin it to the maximum. Then you need to change the direction of rotation of the flywheel. The same must be done with the magnetic flux, the magnetic field is matter. Mathematics sometimes plays a cruel joke in understanding processes.
This is just an episode of many processes in the solid state generator system.
SolarLab
Quote from: rakarskiy on January 12, 2023, 03:23:53 AM
Rakarskiy,
Check out the simulation animated gifs presented in the OUR Holcomb thread - the flux in the LinGen "rolls." The sequence
is set by the controller (microprocessor timing sequence).
Maybe your confused when I say "Controller" - it's the STM32xxx microcontroller or microprocessor that feeds the
Drivers and MOSFETS and sets the timing and sequence. Other than that - no clue as to what you're referring to.
Flywheels, control schemes, mass, direction of rotation, matter - cruel jokes - understanding processes - WTF?
There are quite a few of them so here's a link to a list: (can not post animated gifs on this forum)
https://www.overunityresearch.com/index.php?topic=4261.msg99442#msg99442
And, yea I do understand what I'm dealing with, both with respect to the LinGen, HES and some of the posters here.
It's been analyzed and simulated many times and it works. Mass, inertial and matter are not relavent. basically, I have
no idea what your talking about or trying to convey. Sorry!
SL
Actually I re-read your post, and IMHO your drunk - - -  so now I jealous!   :P
rakarskiy
If the time has not come to realize everything, do not rush.
I won't insist.
Why is the transformer not "OU"? there is also flux linkage and an increase in the magnetic flux in the core.
By the way, the simulator does not correctly calculate the flux linkage in the transformer when the primary and secondary are wound over the first. The simulator will show you that the field is not in the kernel, but it is.
Any program is an episode of mathematical calculation based on the understanding of the operator's processes.
rakarskiy
Quote from: kolbacict on January 12, 2023, 03:21:36 AM
The problem is in the exact knowledge of the processes, what is presented in education is very superficial. Basically, these are instructions on how to calculate the device, according to already proven methods. But - what and how is happening there, far away - is not disclosed. I concluded that accurate knowledge of the processes is part of the so-called "closing technologies"
