0 Members and 35 Guests are viewing this topic.
Ufopolitics
Quote from: rakarskiy on January 18, 2023, 12:57:27 PM
Why did you decide that Figuera does not change the polarity, or rather the direction of the flow? In my research, I just came to this particular system.
Rakarskiy,
I did not "decided"...Figuera did... ;D
Figuera just commutates through an ALWAYS Single Positive Brush, while ALL the other Coils terminals are connected to negative ground.
The commutator is wired in order to pass by the resistors or inductors in between for 180°, to deliver the ups 180° and downs 180°of the signal....which looks like two inverted square Pyramids.
Man, I did Figuera like 10 plus years ago...in real Lab Testing!!
Sorry, but you can not argue with me, how Figuera works...because I have tried every single possibility out there.
Ufopolitics
Edit: Image taken from: https://figueragenerator.wordpress.com/patents/patent-44267-year-1908/
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
SolarLab
 Attached is the timing sequence as I interpreted it from the patent. This sequence was used in the
initial proof-of-concept analysis. Pole 1 thru 4 are N and is same sequence for S; simultaneous.
SL
bistander
Quote from: SolarLab on January 18, 2023, 01:09:55 PM
Your comment:
"If in fact each pole does not swing polarity (N to S to N to S ...) then there are implications seen on the B H curve."
Your answer:"Do you realize that the steel would be working on minor loops regarding the B H characteristics?"
Thanks for your help - a great explanation ( ??? ) and - a super work-around/solution ( ??? )
BTW, the CAE provides a very good picture of whats happening (each nSec) both inside the device material and in
the air around the device - no minor loops (what ever they are) were spotted.
See the gif annimations posted earlier.
Also attached 3 Time Step Magnetic Field Intensity plots. Rotor is clipped - only Stator & LAP are shown.
Plus, LAP [Induced Coil 9] output & all 8 coils. Stepped looking Blue Trace (Coil9 - LAP) is due to low sample/analysis
rate in CAE.
Included the ending sample cartoon as well.
SL
Hi SL,
The highlighted passage indicates that you do know to what I was referring. Sometimes (often?) I try to determine where you're at before spending time drafting a response. It'd be nice if you provided concise answers.
I'll post a graphic which I lifted from here: https://www.researchgate.net/figure/Comparison-of-simulated-FORCs-dashed-lines-and-FORCs-from-HysterSoft_fig3_273143832
It depicts a family of minor loops on a typical B H hysteresis curve. Since the excitation you're using, as I understand it, keeps H positive, the steel in your device is working on a minor loop located in the first quadrant.
I guess this is o.k. I am curious if you realized it. To my knowledge, no conventional electric machinery utilizes such a strategy. As to why? My intuition is that it underutilizes the iron, to the point of requiring twice the mass. Seeing as how yours is not conventional, I don't know that penality applies.
Furthermore, Dr. Holcomb claims his excess energy comes from this alignment of domains 250 times/sec. Might this minor loop excitation limit this energy?
bi
bistander
Quote from: SolarLab on January 18, 2023, 02:01:44 PM
SL
Hi SL,
In the second 8 msec period, no coils are on, correct?
bi
SolarLab
Quote from: bistander on January 18, 2023, 02:32:10 PM
Hi SL,
bi
The sequence is arbitrary (programmable). Analysis used the sequence shown above (each of 4 - 4 sec ON, 4 Sec OFF,
each pulse is staggered by 1 msec).
Good paper re: Hysteresis - when you analyze the GO-35ZH135 or similar material with a DC pulse what do you come up with?
What would the curve look like if it were operated in the psuedo "linear" part of the curve (1.0T for example, no saturation)?
How would you use the BEMF to bring the hysteresis down to near Zero for each cycle? Would that really enhance the
overall device operation?
Are you actually building, or planning to build, a LinGen or similar device? Or is this just a curiousity on your part? If your building
one, or have a team doing the same, are you going to Open-Source it? And if so, any idea when?
GO-35ZH135 B-H Curve shown below for quick reference.
SL
