Floor
I'm not objecting to the explaining of principles of operation, but to say that such and such
"really works", when that "such and such" is already a common and established principle or
method of operation can / seems to imply that there is O.U. there. There is no reason to think such ?
Virtually rotating magnetic polarities and three phase electricity are interesting wangles, for
sure and they "really work" / can be more efficient than other options in various applications.
I'm inclined to say 'so what'... and again ask,  is this Holcomb device topic, about increased efficiency
or O.U. exploration ?
Ufopolitics
Quote from: pix on March 29, 2022, 05:58:31 AM
1. To get the same result it is simpler to use a slip ring AC motor , no need for your setup  :D
Slip Ring Induction Motor - Construction, Working and Its Speed Control (elprocus.com)
Slip ring Induction Motor, How it works? - YouTube
Or even simpler, just use typical squirrel cage induction motor and connect  running capacitors in triangle  and rotate it.  You will get the same thing, AC output.
Cheers,
Pix
Hello Pix,
Thanks for the suggestion, and that YT Video 3D Graphs were awesome, beautifully done...I am going to make something similar in graphics so it would be clearly understood.
However, It will simply NOT work as you are mentioning.
I still see you are not getting it right....you keep anchored to Constant Rotation of Three Phase AC Fields...it won't do it like that
I will repeat myself (again)
There MUST BE COMMUTATION (ALTERNATED SWITCHING) of the SERIES-PARALLEL Coils TO SPIN the DC Magnetic Fields!!
It is Not just to feed Coils continuously through slip rings...no matter if AC or DC feeding.
And so, I do NOT need to rotate the rotor...just the magnetic fields, man!!
But, look, I am making the whole thing so you ALL could watch it in your screens...the real thing...
Just a very small little motor would be rotating huge magnetic fields by COMMUTATION of a Symmetrical winding, found in any Universal Motor...
However, I will wind it myself, from a blank armature core...just to make sure the field width is exactly the same as the Generator Stator Fields...
I will not keep arguing with you or anyone else...until I show you ALL what I mean.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Floor
Quote from: lancaIV on March 28, 2022, 11:52:06 PM
floor,do You think probably in an EMP-magnet and its MMP-output and in-/out-put ratio  or Eta ?
Applied Biot-Savart-/Ampere-/Laplace law !?
WIPO : inventor Dr.res naturalis Pavel Imris,CSc
             or Andreas Schenk,applicant Max Planck Institut fuer Festkoerperphysik (Dresden)
Charles Gilbert Page and Garfield Jr A Wood and Hector :
rotoverter              transverter                ?
rotatory                 translatory              linear
theme terms : beam,trajection
wmbr
OCWL
@Lanka
I don't want to discuss EMP tech. its weaponry, but also not O.U. .
I'm looking for how to do what can be done with permanent magnets, but
with out the permanent magnets.
If Holcomb's device is O.U., maybe it is closely related in some principles ?
Holcomb describes various of his devices but I do not think he understands their
O.U. functioning.
                   Does his device really work ?  Why ?
Every event is mystical when we look deeply enough into it.  Intuition is the common
denominator in all communication.  The symbols / words when also held in common,
facilitate connection to specific areas of the brain, having to do with speech / make
thought accessible to convention and to conventional brain storage / memory...
bistander
Quote from: Ufopolitics on March 29, 2022, 08:13:32 AM
Hello Pix,
Ufopolitics
Hello Ufo,
Pix is correct/you are mistaken. His video does a nice explanation. This "rotating magnetic field" in the 3-phase stator is what I've been attempting to show you for years. It may be difficult to grasp at first, but is quite eloquent. It is in fact a constant magnitude (as you call DC) magnetic field which travels in space (and steel) with stationary apparatus. No physical motion required, just polyphase AC applied to the winding.
bi
pix
Ufopolitics
Ufo, you don't need to rotate anything.
I already mentioned it many times - in Slip Ring AC motor when you LOCK rotor from rotating, and feed 3 balanced sinusoidal signals to the slip rings, you will have ecactly what you want to achieve with your commutator,slip rings and a small motor: rotating DC magnetic vector.
Such locked rotor situation is a TRANSFORMER.
And it doesn't matter which way you are going to rotate DC magnetic vector- by your slip rings and small motor, or by use of balanced 3 phase signal- LENZ law apply.
And no OU there.
Cheers,
Pix
