Ufopolitics
Quote from: pix on March 29, 2022, 09:15:27 AM
Ufo, you don't need to rotate anything.
I already mentioned it many times - in Slip Ring AC motor when you LOCK rotor from rotating, and feed 3 balanced sinusoidal signals to the slip rings, you will have ecactly what you want to achieve with your commutator,slip rings and a small motor: rotating DC magnetic vector.
Such locked rotor situation is a TRANSFORMER.
And it doesn't matter which way you are going to rotate DC magnetic vector- by your slip rings and small motor, or by use of balanced 3 phase signal- LENZ law apply.
And no OU there.
Cheers,
Pix
Thanks Pix,
In my setup, I do not need to go and find any EXTERNAL Three Phase balanced sinusoidal signals...I will generate them, I can make single phase, two phase or three phase and very well balanced...depending on the Generator Core and coils utilized.
I am going to start off a Single Phase Generator Head, built from factory windings first, without OEM Rotor, to make things simple to "digest"...and you know every single phase genny comes with two outputs, one Main AC and a secondary pair of coils which are typically connected to a running cap...right?
Well, those two secondary coils and cap are in charge to induce rotor coils back in a normal rotary generator...correct so far?
This is the famous "loop back" that takes place in the Excitation System (Stator Secondaries>Running Cap-Rotor Coils>Closed circuit with Diodes) of every Brushless Generator out there....
I will show you in real time, that after having the fields rotating, and adding the right input to exciter stationary coils in order that secondary start generating induced EMF...then... ;D
You will see how I get that running cap terminals and plug them into the Input of Stationary Rotor...then disconnect the power in (PSU) to Stationary Rotor and it will not collapse...it will keep feeding itself.
How is that to start a demonstration here?...
Just give me the time to set it all up...need to get a lot of stuff together first...then build, build and build...
However, I will be migrating all into a Moderated Thread...and you will see it all there...promise man!!
Cheers...We got it bro!!
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to All,
Let me be straight and right to the point here...
I know everything about the history of "Loopers" in the past...and it never ends right and well.
I will NOT hide ANY "secrets" from anyone who is willing to replicate my design...as I am NOT planning to Patent nothing...
However, I do need "Protection"...but wait...do not get disappointed... :)
My "Protection" will be that as many of you as possible, are successfull in replicating my setup, BUT, in exchange, I will ask you to SHARE IT WORLD WIDE and as fast as you could!!
IT NEEDS TO BE WIDE SPREAD AND VIRAL...ASAP!!
I have more than 7000 subscribers in my YT Channel...But not enough...it needs to be spread fast and viral...
That's all folks
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Hey Pix,
Man, did you finally take the same stuff that Ianca is taking?...LOL  ;D
Just checking...
Ufopolitics
―Leonardo da Vinci
listener192
Just rotating the poles will not provided good induction in the three phase output coils. The poles must have a variable flux as they rotate. He claims that he  achieves this via the inner coils which have a variable amplitude flux over the three active coils in each pole (shown in the patent).
L192
