0 Members and 18 Guests are viewing this topic.
SolarLab
Quote from: kolbacict on February 28, 2023, 10:06:35 AM
Why does my output power taken from the rotor depend on its position inside the stator?
At what angle is it rotated inside. I think you do too.
Doesn't this mean that we consume something else from the stator besides the rotating field ?
This is direct induction as in a conventional transformer.
It is could for you to achieve that at any position of the rotor inside the stator, the output EMF does not change ?
This will mean that the energy in the secondary is available only due to the rotating field.
And nothing else.  I haven't been able to achieve it yet...
Hi Kolbacict and Bistander,
Thanks for the great question (... position inside stator). Got me thinking about the physical
configuration with respect to the LinGen and the saturated output anomoly - fooled with the offset
a bit just now (Magnetostatic) and you may have hit the JackPot!
More later, as it develops - Free Beer if it works out... Thanks Again!
SL
PS - also fixed the cartoon over-size.
SolarLab
Quote from: rakarskiy on February 28, 2023, 02:28:21 AM
Hello SolarLab!
I would not rush to conclusions: P = UI = 400V * 1A = 400W (This is a serious statement).
For such an indicator, an appropriate core is needed for the corresponding Ф=BS magnetic flux. Further, your 400V peak value should correspond to the formula E = 4.44 Фf.
You modestly kept silent about the resistance of the circuits, the cost of excitation, the places where the magnetic flux from the wires of the phase winding disappears.
I won't jump to conclusions, I'll wait for more serious tests of your generator. I hope to see a picture of the device to see the scale.
Sincerely, and I look forward to your new data, with more detailed design and calculations of the corresponding episodes of the generator.
Hi Rakarskiy,
A bit more in response to your comments and concerns. The attached notes are from a COMSOL course a while
back as I recall - can't find it on the internet however; so it's attached.
Covers both Analytical and Numerical approaches to a Fault Current Limiter design but the first five chapters are generic
to developing most devices of similar structure, including the LinGen. It's quite comprehensive and well done IMHO.
You're probably intimately familiar with most of the stuff covered however it might be a useful read for others.
Hope we can compare your analytical data with my numerical data sometime soon - I'm curious to review the results.
SL
Attached: "Winded Coils and Ferromagnetic Cores" a.k.a faullt_current_limiter.pdf
kolbacict
Use beam modulation  with certain frequency,and you can measure speed of rotation magnetic field.
https://youtu.be/9IBGr7OAkbM
https://youtu.be/Del6ztSKttw
kolbacict
bars of transformer steel (sets of that plates) were placed between the stator and the glass tube of the kinescope.
Similarly, as it is done in mechanical magnetic gearboxes.
In order to increase or decrease the natural rotation speed of the field.
The picture on the screen has changed, but I have not recorded a clear change in the rotation speed.
Interpret the picture , the data received is not enough mind.
If you don't want to help ме, I have to myself... :)
p.s. https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/dlattach/attach/189964/image//
What is this?
