qwekw
Anti-magnetism annihilation permanent generator
[Claim(s)]
[Claim 1]
A power plant which used as resources space which takes out the big energy generated
at the annihilation quantum reaction of the right magnetism which carried out pair
creation to the ring-core type magnetism mini black hole placed into the revolving
magnetic field, and anti-magnetism as electric power
[Claim 2]
A permanent power plant which returns a part of output power which occurred by an
annihilation quantum reaction as input energy, and could be made to do power
generation with the circuit system by electric power multiplication eternally
[Claim 3]
The system which increases and takes out the input power from [ a small portion of ]
the outside to big electric power by the electric power multiplication of this
equipment
[Detailed description of the invention]
[0001][Field of industrial application] The power supply for electric vehicles,
generator for plant
[0002]The power plant of the [Description of the Prior Art] former is generated with
the energy by nuclear fission etc. using a fossil fuel, uranium, etc. [Problem which
invention solves and it makes like] Although the method of converting mass to energy
has nuclear fission and an annihilation reaction by combination of nuclear fusion,
other particles, and an antiparticle conventionally, the antiparticle cannot perform
extensive generation by some labors in the present technology, but utilization is
still impossible. Then, anti-magnetism is one of those can carry out extensive
generation by some labors instead of an antiparticle. If there is anti-electrical and
electric equipment of an anti-electron and antiproton, naturally it will be
predicted that there is also anti-magnetism and an antiparticle and anti-magnetism
will become equivalent in terms of quanta.
[0003]If there is an annihilation reaction of an antiparticle, naturally, there is
also an annihilation reaction of anti-magnetism and it has taken out the big energy
generated at the annihilation reaction by combination with right magnetism and
anti-magnetism as electric power. Although an antiparticle is if it is simply
generated around the black hole in Dr. Hawking's theory, it is impossible for us to
obtain the antiparticle.
[0004]If a ring-core type magnetism mini black hole is built on [Means for Solving
the Problem], then an artificial target, anti-magnetism is easily generable with
slight energies. When it describes with Drawings, [ the structure of a magnetic mini
black hole ] By the method of Fig.1, a plurality of coils of about 50-set 50 phase
are wholly rolled in the same direction like 2, and 50 sets of leads on the winding
start side are packed into one, and it is considered as one pole, a total of 50
rectifiers 3 are altogether prepared in the direction of the winding finish side on
the pole of the same +, and it collects into the surroundings of the ring core 1 one.
[0005]If the coil 5 for three phase alternating currents is arranged the outside and
inside a ring-core type magnetism mini black hole, and an about 600-Hz three phase
alternating current is passed inside and they are made to generate a revolving
magnetic field like Fig.2, If induced voltage occurs in the coil of a ring core and
the output current is rectified, it will become a very smooth direct current by a
plurality of source resultant pulse numbers and capacitors 4. [ about 25 sets of the
single-sided half of 50 sets of coils wound around the ring core ] The induced
voltage of a forward direction occurs to a rectifier, and the induced voltage of an
opposite direction occurs in about 25 sets of the remaining one side half, Since
current flows into the coil of the single-sided half of a ring core, positive
magnetism occurs and current does not flow into the coil of the remaining one side
half, there is no electromotive force, but the equivalent anti-magnetism by an
equivalence principle is generated, and the rotary type pear of the right magnetism
of Fig.3 and anti-magnetism is generated instead of.
[0006][Equivalent description of anti-magnetism] Although there are an electromagnet
and a permanent magnet in a magnet, only in the single-sided half of a ring core like
Fig.4, densely, about a coil, when winding current is sent, the inside of a ring
core has little magnetic resistance, and magnetic flux becomes the one closed
electromagnet A which aligned at the single tier. However, two magnetism of rightward
facing the left like Fig.5 occurs, two points which collided become a n pole and the
south pole, and the massive ring core placed into a revolving magnetic field like
Fig.5 and the magnetism which the induced current by a revolving magnetic field
flowed through and generated in the short-circuit-winding type ring core become A and
a B-2 piece magnet. If an induced current flows into the ring core placed into the
revolving magnetic field, A and the B-2 piece magnetism which faced each other will
usually occur.
[0007]In the case of the ring-core type magnetism mini black hole of Fig.3, In spite
of being placed into the revolving magnetic field, A and B-2 piece magnetism occur in
the direction which aligned at the single tier, It is not because unlike the case of
ordinary electromagnet Fig.4 B was only **(ed) by the magnetism of one side A and it
aligned, It means that an anti-electron is electrified physically at the
surroundings on the ring-core B side, it regards that it is equal to the
magnetomotive force which occurred since anti-current flowed, and the anti-electron
is flowing physically by the equivalence principle of an electromagnet and a
permanent magnet even if the anti-electron is not actually flowing into the
surroundings of B, and anti-magnetism was generated. Anti-magnetism is in direct
proportion to output power, and is generated. Only when the ring-core type magnetism
mini black hole is placed on in the hall [ by a revolving magnetic field /
electromagnetic ], pair creation of the equivalent anti-magnetism is carried out, and
in ordinary electromagnet Fig.4, the magnetism of the whole ring core only turns
into a series of closed right magnetism.
[0008]The point which it is careful of needs to make output current the smoothest
possible direct current, in the pulsating flow of exchange or change with an intense
output, in the magnetic flux which occurred in the ring core, a direction changes
with change of output current continuously, magnetic flux flows out outside then,
magnetic energy is lacked, and pair creation does not break out. Since an inductance
is high, a voltage drop breaks out. Since the pear of the right magnetism which
carried out pair creation into the ring-core type magnetism mini black hole, and
anti-magnetism annihilates, magnetic flux is not emitted outside but is nonresistant
to an outside revolving magnetic field, It does not act on an external three phase
coil, but the three phase current of an input has the power unrelated to the size of
downstream output power by Lenz's law, and it is substantially fixed. Input power is
the agency energy for inducing a pair creation reaction, and is not the energy of
direct-output electric power.
[0009]Like Fig.6, by returning the electric power of 1(4%)/25 degree of a dc output
as electric power of a three phase alternating current inverter, and circulating
through it, pair creation and an annihilation reaction can be caused continuously and
continuous big electric power can be taken out by electric power multiplication.
Power generation as output 15kW can be performed like input 500W as an example.
[0010][Effect of the invention] This permanent generator is an electric power growth
machine using the annihilation quantum reaction of anti-magnetism and right
magnetism, Since the power supply for electric vehicles and the large-sized thing for
plant can also be built, and a fossil fuel etc. are not needed like the conventional
power plant, since big electric power can be generated even if small, but infinite
space serves as resources, it becomes energy saving and pollution-free permanent
clean energy.
[Brief description of the drawings]
[Fig. 1] It is a schematic illustration of a ring-core type magnetism mini black
hole.
[Fig. 2] It is a plan view of the three phase alternating current coil for revolving
magnetic field generating.
[Fig. 3] It is the right magnetism and the plan view of anti-magnetism which were
generated in the magnetic mini black hole.
[Fig. 4] It is a plan view of a ring-core type electromagnet.
[Fig. 5] It is the magnetic plan view generated in the massive ring core by the
revolving magnetic field.
[Fig. 6] It is a schematic illustration of the permanent generator by circuit system
[Explanation of letters or numerals]
1. Ring Core
2 Five-Step Pile Coil
3. Rectifier
4 Capacitor
5. Coil for three phase alternating currents
6 600Hz Three Phase Alternating Current Inverter
onepower
qwekw
It's a wonderful theory but not nearly complex enough...
I think we would require much more anti-magnetism, anti-electrical, anti-what-ever-you-call-it, multiverses and worm holes to even make a dent in the current paradigm. Maybe even multiple rabbit holes where we could simply de-materialize and jump down all of them simultaneously... wouldn't that be something.
AC
bistander
kolbacict
Quote from: bistander on March 04, 2023, 12:50:37 AM
Appears off-topic. Perhaps a devoted thread?
bi
Well, I have messages on the case. But again no one pays attention.
Maybe you just want to chat, relax ?
If the field with my iron bars will not spin faster, or at least slower,
That means the field is not real, it's all an illusion.
bistander
Quote from: kolbacict on March 03, 2023, 11:15:19 AM
bars of transformer steel (sets of that plates) were placed between the stator and the glass tube of the kinescope.
Similarly, as it is done in mechanical magnetic gearboxes.
In order to increase or decrease the natural rotation speed of the field.
The picture on the screen has changed, but I have not recorded a clear change in the rotation speed.
Interpret the picture , the data received is not enough mind.
If you don't want to help ме, I have to myself... :)
I pay attention to you, but do not understand your experiment. Sorry. Had hoped to learn more from other replies. Since we see none, can you expand.... Show more? What/how you did it? How you measured? What you are after? You mentioned mechanical gearbox analogy, please give example reference. How is this on-topic to Holcomb? Are you attempting to see gain by inserting steel?
bi
