Jimboot
rakarskiy
QuoteInterestingly, if you try to run it without a significant enough load, Pin will exceed Pout. So the load is part of the effect.
Jimboot, you will be surprised, but the traditional generator works on the same principle, where the load is dominant for the magnetic system of the generator (more precisely, the current from the phase that forms the magnetic flux in the core), and the lifting system plays the role of control. I also came to the conclusion that it is necessary to excite the current in the phase and coordinate with the excitation.
In addition, I nevertheless came to the conclusion that I was doing exactly the transformer version, in fact, this is Figuera. In such a system, there are difficulties with starting.
Electromagnetism cannot destroy the second law of thermodynamics, and the Carnot cycle has nothing to do with electromagnetism.
Thanks for the review!
Jimboot
Quote from: rakarskiy on March 10, 2023, 06:59:31 AM
I'm learning more everyday:) Thanks mate. I'm working with a washing machine motor atm. The rotor had 8 perm mags in between steel laminate wedges and then dipped in epoxy. Removing them I'm left with a 8 pole rotor. My slots for coils is only 8mm though so I won't be using 18awg 5 in hand though. I'd like to explore the effect more using the caps and a multipole rotor before printing and sintering a new rotor. I have to print a new winding jig first like Holcombs then do the calculations for my winds/caps. I have renewed enthusiasm. :)
rakarskiy
Hi Jimbut!
I think that this core is unsuitable for a solid-state rotor on controlled electromagnets. This design is a good permanent magnet rotor for generator. I found the first instance of such a decision in 1989 (USSR)
I am just describing the work of a magnetic field, such a rotor in terms of the topology of the magnetic flux in a synchronous generator.
https://patents.su/?search=1495929&type=number
