0 Members and 52 Guests are viewing this topic.
listener192
Quote from: pmgr on March 24, 2022, 04:00:02 PM
@Ufopolitics et al
Some points I would like to make:
1. The driver circuits that are in that particular patent are nothing special as far as I can tell (correct me if I am wrong). It's a simple bidirectional coil driver (similar to what a bidirectional motor driver looks like). Nevertheless, from his patents (and I have read all of the most relevant ones now) it appears Holcom doesn't understand where his excess energy is coming from, repeatedly stating electron spin in electrical steel, high permittivity etc as the explanation. That is not the cause, as we know it takes energy (B*H which is the area under the hysteresis curve) to magnetize and demagnetize material and there is no gain in that). But maybe he states that because he really doesn't know and probably had to give some explanation in the patent (after all he is not an electrical engineer; I believe was a medical doctor in the past). Looking at how detailed his patents are, I don't believe he is deliberately steering someone in the wrong direction.
2. If you take a look at the old Pierre Cotnoir's DZ generator threads, you will see Pierre was using a similar scheme of a rotating magnetic field generated by DC currents, but with relays instead of FETs. Although Pierre's device seemed to work from his videos, nobody has been able to replicate it.
3. I believe that the reason that Holcombs device works is because he has found a way to circumvent BEMF from coupling back into the rotor driving coils. I am not so sure if he actually understands that that is what he has done as he keeps on stating no BEMF because the rotor is fixed, but that's not the reason why it works. The reason it works is because the BEMF is diverted and doesn't make its way back to the driving coils. I will need to confirm what I think is happening with some calculations to be 100% sure, but based on what I can picture in my head so far, it should work that way.
Lastly, with respect to noise on this thread, indeed a lot of random noise (no need to state a name here) so I am all for a moderated thread. But please don't censor anyone if they have a different opinion or shoot down someone else's explanation with sound reasoning. A healthy discussion benefits all as long as it is polite and explained with reasoning (so no name calling, insults and things of that sort please).
My two cents, PmgR
This would be my take on how OU is acheived with this device, BEMF circumvention via the three phase stator core. A reproduction of the magnetics in FEMM would allow the coupling factors to be verified both ways between the energizing coils and the output coils. It is also noteworthy that one patent implementation has an additional stator core between the inner core and the output core. This has no windings.
L192
pmgr
@L192
Yes that inner part with no windings is visible in the simulation in his video, yet not in the real device. The only thing I can think of is that it is expanding the poles of the very inner rotor so they spread a larger area to avoid saturation. I have to dug into this a bit more to see if there is another reason.
Update
The configuration for his simulation image is actually a stator-double rotor-stator-rotor configuration, but same operating principle, all rotor fields re-inforcing themselves. Only reason this is done is to increase the power output.
pix
Quote from: listener192 on March 29, 2022, 12:10:02 PM
Just rotating the poles will not provided good induction in the three phase output coils. The poles must have a variable flux as they rotate. He claims that he  achieves this via the inner coils which have a variable amplitude flux over the three active coils in each pole (shown in the patent).
L192
Lenz law still apply.
It applies for rotation ( motor/generator action).
It applies for flux intensity variation ( transformer action).
Cheers,
Pix
pix
Quote from: Ufopolitics on March 29, 2022, 10:05:18 AM
Hey Pix,
Man, did you finally take the same stuff that Ianca is taking?...LOL  ;D
Just checking...
Ufopolitics
Didn't took any stuff in my life.  :)
Ufopolitics
@L192:
Does the constant Rotating Magnetic Field on a Typical 1,2,3 Phase Rotary Generator ever fluctuate (Variable Flux amplitude)?
@Pix:
I was joking about what you wrote before..."taking  same stuff as Ianca in order to understand him"... :)
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
