0 Members and 54 Guests are viewing this topic.
bistander
Quote from: kolbacict on June 07, 2023, 11:10:08 AM
p.s.
Why no one pays attention at similarity of Holkomb's device and https://en.wikipedia.org/wiki/Induction_regulator ?
Which is used from 1930 years !
Or.
https://en.m.wikipedia.org/wiki/Synchronous_condenser
Or as I've asked numerous times, the 3-phase wound rotor induction motor at stall. That is exactly what Holcomb describes.
bi
onepower
Beginners mind
It's hard to say what's going on but I see several red flags...
1)A supposed former possibly disgruntled employee is making the claims.
2)The supposed buyers name, Mark Koch, rings a bell. The Koch family were to oil and gas what the Saklers were to opiates. Ruthless and supposedly as psychotic as it gets.
3)This is in Florida which is like a magnet for crazy people. It's a hot bed for populism, mass shootings, drug addiction, corruption and homelessness.
QuoteCareful review of the video demonstration showed that HES wires their 3-phase power meters incorrectly.  The voltage and current probes are not attached to corresponding phases.  An HES engineer in the video acknowledges this, clearly believing it to be correct, without intention to deceive.  But this is a tremendous error in 3-phase metering, which here results in meters reading more power out than in.
Fair enough, but it assumes that more than a few qualified people missed this through all the testing with countless different devices. 3 phase is easy to understand and it follows the same basic rules as all other electrical power. A real load always produces a voltage drop and a current increase to support said voltage drop. So we pick one loaded phase (1-phase) plus neutral and measure the power before the HES device while it's in operation and not. If the loaded 1-phase power drops while the unit is in operation then we have our answer.
It's problematic because most people don't understand 3-phase power or power/energy in general. If the 3-phase power is supplying a whole building then it's a given that it's using 1, 2 and 3 phase power. Lights, small appliances ie. small loads don't run on 3 phase they run on 1 phase.
AC
rakarskiy
Cotnoir turns out to be how he commuted his windings.
Of course,it was on this forum, and everyone who desire to see it.
But I found it in saved last year's files.
p.s.
switching is nothing more than an engineering solution, I had the same one!
bistander
Quote from: onepower on June 07, 2023, 12:08:51 PM
Fair enough ...
AC
Quite unfair, AC. Mark W. Koch appears to be a respectable citizen living near Nashville TN. Mentions "Caney power bill" appearing to refer to Caney Falls electric coop of McMinnville TN.
I see no reason to connect him to the infamous Koch brothers and Salkers. Can you provide reasons you did that?
bi
nix85
Regarding the 3 phase generators in general, just to remind ALL coils are wound in same direction (CCW) as clearly seen in first attached image. Notice in this animation connections are wrong, one of the 3 coils of a single phase is flipped which should not be.
https://www.youtube.com/watch?v=_jaIHJUf110
Also, as diagram below shows, induced voltage is max when flux is 0 cause that is when rate of change is the greatest.
Two last images below show lenz law in action. If north flux passes across the wire as shown electron will be pushed up, no matter which way you close that loop, whether you make the flux enter the loop or exit it, irrelevant, electron will go up, always.
Same thing is visualized in last image, screenshot from great canadian documentary. Screenshot demonstrates the motor effect aka laplace's force, but it is just an inverse of lenz law, in fact it is one and the same.
In the screenshot electron is going to the right, toward the screen and wire is immersed in flux as shown. Left hand rule shows that wire is pushed downward and it is pushed downward cause flux of the wire and flux of the magnets are in same direction above the wire, thus repelling.
Exactly the same stands for the reverse, no current in the wire, wire is going up into the flux, electron will go to the right and magnetic field will be generated as shown, repelling above, pushing the wire down (lenz).
Again, no matter how you close the loop matters not.
Left hand rule also has 2 more applications, as shown in the documentary. If you curl your left hand fingers with the solenoid turns, your thumb is pointing toward the north pole. If you point your finger in direction of an electron going through a wire curved fingers show the direction of the flux around the wire. There is also a 3rd application of left hand rule shown in the documentary, not really important on macroscopic level for it is for a single electron, similar to the noted method of finding a north pole of a solenoid, curving fingers in direction of electron's spin around its own axis thumb points toward the north pole of the magnetic field it generates.
These are some fundamental principles that often get forgotten or are not understood well in the first place. All this must be absolutely clear if one wants to find a way-around lenz.
