Ufopolitics
@L192,
Ok, thanks...let me ask you, the red coil top right has other red Coils below, is that the way you wound each coil, by stepping forward (to the bottom of screen) or jumping one slot at a time?
And if you could also provide Coils interconnections plus all terminals (36 right?) for switching...
Thks
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pmgr
Pierre wired it moving over one slot at a time, not stepping over the blue coil and continuing there.
I understand what you are getting at Ufo; you would want to see it wired like a general 3 phase stator, but Pierre didn't do it that way. Neither did the replicators. And the outer iron is the "rotor' in this case, not the stator. Center iron is the stator (where you pick off the output). The stator has only two poles (two ends that interact with the field).
Anyway, the reason there is no flux in the center iron is because the way this is biased with 6 poles is such that it creates a magnetic field from each N-S pole pair into the center iron, but all three poles are 120deg out of phase, so in the center iron, it adds up to ZERO. Magnetic fields are not just magnitudes that add up; they also have a phase and order to get constructive interference, the phase would need to be the same for all 3 pole pairs which it is not in Pierre's case.
Ufopolitics
Quote from: pmgr on March 30, 2022, 03:58:28 PM
Quote from: pmgr on March 30, 2022, 03:58:28 PMI understand what you are getting at Ufo; you would want to see it wired like a general 3 phase stator, but Pierre didn't do it that way. Neither did the replicators. And the outer iron is the "rotor' in this case, not the stator. Center iron is the stator (where you pick off the output). The stator has only two poles (two ends that interact with the field).
Hey PmgR...are you trying to read my mind, or guess here, assume my thoughts now?...hahahahaha
Man, of course, I know very well in Pierre's design, the Outer Core are the Rotating Fields as the Single Inner Coil is the Stator, or Secondary where output is taken from...Duh!
(I just do not want to take your comment above seriously... so I rather laughed).
Quote from: pmgr on March 30, 2022, 03:58:28 PMAnyway, the reason there is no flux in the center iron is because the way this is biased with 6 poles is such that it creates a magnetic field from each N-S pole pair into the center iron, but all three poles are 120deg out of phase, so in the center iron, it adds up to ZERO. Magnetic fields are not just magnitudes that add up; they also have a phase and order to get constructive interference, the phase would need to be the same for all 3 pole pairs which it is not in Pierre's case.
Magnetic Fields DO ADD UP as simply as 2+2=4, depending on how they are set spatially.
So, I see you've got "all the answers" as why it does not work?!!
Did You Replicated this setup from Pierre, PmgR?
Please, let me finish with L192 (without interruptions)...as all I am trying to do here, is to help him on his excelent replication.
I will appreciate it.
Thanks
Ufopolitics
―Leonardo da Vinci
Cadman
Excuse me for butting in but I always thought he wired it to be 2 poles (NS) 180 degrees apart and stepped the connections to rotate the 2 pole field.
Cadman
Ufopolitics
Quote from: Cadman on March 30, 2022, 04:18:13 PM
Cadman
Hey Cadman,
Many years back, I also thought like you wrote above...as I test it and it did not work as expected...I stepped Two Isolated Coils apart at 180 degrees at a time (switching)...and overlapped with next pair...I did get output, it does induce...but not the way that we all are looking for.
Ufopolitics
―Leonardo da Vinci
