bistander
Perhaps this Q & A can bring some clarity.
tinyurl.com/QuoraFluxLines
QuoteAnswer to When the conductor cut the magnetic flux lines then the electrons in the conductor exited, does this mean the electron is gaining the energy from magnetic flux lines? by Parvez Siddiqui
Equations and diagrams copy/paste poorly, so I'll attach screenshots of what is in the link.
bi
nix85
I have proven it since day one and your "simulation" just confirms all i said.
It does not matter what the flux density is in the wire, you lunatic,
change of flux through the coil is what matters here.
In your own diagram flux through the coil increases 3 times as magnets approach.
You can't calculate it even if you had the speed, of course you don't understand that
you can't calculate EMF without speed, and that there is no need to calculate it, ALL
that matters is there is a large change of flux through the coil as magnets approach.
From 0.12T to 0.37T in your "simulation".
Now go back to your sanitarium and tell your tales to the lunatics.
rakarskiy
Quote from: bistander on June 23, 2023, 01:40:51 AM
tinyurl.com/Quora-Flux-lines-Q
bi
In an experiment with magnets and a conductor?
Take and prove these conclusions before the variant experiment. I do not mind. Only mathematically with the values.
By the way, if you take a ring of core with a wire in it and change the magnetic induction from zero to maximum and back, there will be EMF in the conductor according to the formula, which is engineering
nix85
There was no need for that screenshot for there is nothing in it that has not
already been shared here, all formulas for induction, for flux linking, flux cutting,
even Maxwell's laws. And that guy is obviously very very ignorant and 100%
conventional claiming magnetic field does not impart kinetic energy to the electron.
That guy would equally say magnet-only motor is impossible, anyway.
Point of this discussion is ALL that matters is there is a large change of flux through
the coil as magnets approach to the closest point, EMF is induced in normal manner.
bistander
Rakarskiy,
It has been proven millions of times, perfectly.
It has worked for me personally, perfectly, every time, hundreds, if not thousands of times, with real machinery.
bi
