kolbacict
It came my mind the other idea.
We  appeared in court as victims of fraud HES   ?
Maybe even we can sue some money to naturalize in the US ?
SolarLab
OT - sorry...
TL,
Thanks, they all have been dropped there.
Directory (?) of the "Magnetic Field Intensities" are the ones that look like these:
Have a good one!
SL
kolbacict
Quote from: rakarskiy on June 23, 2023, 01:52:46 AM
By the way, if you take a ring of core with a wire in it and change the magnetic induction from zero to maximum and back, there will be EMF in the conductor according to the formula, which is engineering
I have that. From drum VCR. There you go?
The coil is whole covered of ferrite.
I can do my experiment. :)
rakarskiy
Quote from: bistander on June 23, 2023, 02:10:15 AM
Rakarskiy,
It has been proven millions of times, perfectly.
It has worked for me personally, perfectly, every time, hundreds, if not thousands of times, with real machinery.
bi
Exactly on the contrary, in stator slot I never managed to fulfill the condition for the formula (E=Blv) and even for the formula in the linear interruption of the flux in the core (E=4.44ϕf)). But making various measurements I saw a pattern, then I checked it and got an answer, how the electromagnetic induction works in the stator slot according to formula (E=4.44ϕf). In addition, all the rest all came together in a very logical chain.
At the moment I find out how the transformer works, there are interesting moments there too. If I can get rid of or tame something, I will tell exactly how to make a transformer into a generator. In addition, the direction just opened in the direction of CAPAGEN and others.
Holcomb himself probably does not fully understand how it works, judging from the estimates of his explanations, visitors who have the appropriate profile education.
By the way, I want to repeat the simplest generator with a core, only without magnetic rotating rotor, but with an electromagnetic solid-state, this is to consolidate the whole theory to popularize the method.
"To understand how a synchronous alternator works, where the winding is in the slot or on the coil core, it is enough to consider the simplest synchronous alternator.  It does not matter what will cause the change of magnetic flux in the core, a mechanical magnetic rotor or a solid-state fixed solenoid switching system according to a given algorithm."
https://rakatskiy.blogspot.com/2022/06/overunity-holcomb-energy-system.html
SolarLab
Recent Update
https://www.facebook.com/holcombenergysystems
"Astra also plans to deploy Holbomb Energy Systems ( www.holcombenergysystems.com )
cutting-edge In-Line Power Generator solution to amplify the project's output, helping to support
Zanzibar's move toward energy independence."
Astra Energy Inc.  www.astraenergyinc.com
SL
