0 Members and 138 Guests are viewing this topic.
bistander,can You give me an example from an electric motor (Wp,Wnom) which is sourced by an AC car alternator(VAp,VAnom) DIRECTLY  ?
Car alternators were mainly battery loading devices,f.e. for the ic-engine ignition and lights.
Magnetomotive FE-devices are not build with ordinary steel grade !
Soft/amorph/perm-alloy ! ~ similar supermagnets material
3/4d Physics     +    3/4d chemistry re-/search !
The know-how           of material/-configuration/-creation  use !
wmbr
OCWL
rakarskiy
bistander, you can save the term "as a rule" for students! There is a separate group of steel for dynamic electric machines, theoretically it can be used for all types of products. But if only it were so clear-cut. The generator has such a moment that is taken into account for the addition of fields, in the motor the fields are closed. The operation of these two synchronous machines is different and very different. About reversibility is a perl of physicists, like "see it rotates", and in fact a good motor is a bad generator (the fact that the motor is put for the function of the generator, is absolutely not an indicator, almost all who faced rewind), and a very good generator, no motor at all: (by the way, the car generator let as a motor, disappointment will be the characteristics of the motor).
Just six months ago, a guy I work with was looking for the right steel. Found it, turned out to be no easy task at all.
bistander
Quote from: lancaIV on August 07, 2023, 08:19:21 AM
wmbr
OCWL
Once your car is started, you can remove the battery and it and all accessories like wiper and blower motors operate just fine from the alternator, with diodes of course. Without diodes, the car alternator would be an odd 3ph source, but I suppose any universal motor would run from one phase directly.
"FE-devices". What are you talking about? There is no FE-device.
bi
rakarskiy
Quote from: lancaIV on August 07, 2023, 07:20:04 AM
Rakarskiy,
1975 not approved utility model or approved technical standart patent application( FR:  A1,B1) ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19761217&CC=FR&NR=2312135A1&KC=A1#
Where can I find a copy of this patent, according to the description the design coincides with the MEG of Tom Bearden and Co. or EasyMEG, only in such a configuration as a generator works only EasyMEG and that I had to specify something.
