Ufopolitics
Quote from: listener192 on April 01, 2022, 02:51:46 PM
There certainly is enough detail in the patent to allow a replication.
I don't think any standard motor or generator stators could be used though.
I think they would have to be laser cut, which along with the cost of sheet silicon steel, is an expensive undertaking.
@Listener 192
I do not need a Patent to build the primary concept, which is what I am putting together.
The concept is so simple...I was making a mistake in the past, which gave me output but no OU...
For the last couple of weeks the words from Tom Bearden (RIP) keeps pounding in my ears : "Do not kill the Dipole!!
Now, I am sure it will be much more positive results than I had in the past 6 years.
Main error...I was Collapsing the Magnetic Field in every single angle turn (Asymmetrical Winding of Isolated Coils apart by 180º)...not good, the Field MUST remain in at least 85-90% ON at all times during operation.
A standard Generator head stator would do, just taking off the rotor and replacing it with a Lap Winded armature at very closed gaps.
I do not agree that it is required any 3 Phase AC like to turn the fields...at all!!
If You want 3 Phase AC output, then get or wind a 3 Phase Stator...but the rotor technology is exactly the same for 1,2,3 phases.
Even with a Universal Motor (OEM, as is) we will see anomalies...not easily understood.
Laser cutting is too expensive...I had cut laminations of 2.0 mm with Waterjet tech (many years back)...then stack them together, apply MIG welding tack points and high temp. epoxy all interiors and top-bottom...ready for winding... :)
I have done that so many times...in  so many different configurations.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
About my previous post...
It is obvious that the Lap Armature or Stationary Rotor now, to be inserted into a Gen Head Stator, needs to be rated for 120-180 VDC and from 2 to 5 amps min.
For the generation of a strong enough field, we need a Higher Voltage than one Main Out V...(eg: 170V In 120 Out) as only 2 Amps required into rotor for an output from 25 to 20 Amps in just one single phase.
Of course, a 220 Output will put half amperage than 120V...the same exact thing as it works on a typical Rotary Gen...
As every Gen Stator has a secondary set of coils set at 180° just to feed rotor...
Cheers
Ufopolitics
―Leonardo da Vinci
pmgr
Below is the explanation of the so-called free energy. Makes no sense. He is simply explaining a B-H curve of electric steel. In a PV array, indeed photons are converted into electrons in a wire.
But this is magnetism. No electrons hopping from the steel into the coils... the magnetic fields moving the electrons in the coils, that is called induction. Nothing special about that.
kolbacict
And the installation of Clement Figuera is not about the same thing ?
Only in linear version.
Or is there no traveling magnetic field in this ?
listener192
Quote from: pmgr on April 02, 2022, 01:13:28 AM
Agreed nothing special there.
There is no full explanation of how inner rotor tuning capacitance reduces the generator rotor coil impedance by 50%, which then allows each inner rotor pole to devlop 4.3 units of power in the output stator for each unit of power fed back from the output stator windings.
Reading the patent again this appears to refer to the inner rotor coils, not the outer rotor coils, which only develop a weak flux into the output stator, as their steel poles have large airgaps in the closing members either side.
L192
