0 Members and 25 Guests are viewing this topic.
rakarskiy
Quote from: listener192 on August 12, 2023, 10:46:09 AM
You are misinformed about the availability of the journal in question.
For those that are interested here is the publication https://www.biodiversitylibrary.org/item/53496#page/179/mode/1up     page 161
This occured after the publication of Faradays Paper and not neccessarily before Hippolyte Pixii's device became knowledge.
https://commons.wikimedia.org/wiki/File:Hippolyte_Pixii_dynamo.png     and many other sources state Pixii was the first.
The source of your information , a Scottish Professor Patrick John McLaughlin, in a 1948 publication Studies: An Irish Quarterly Review, article  "The Irish Inventor of the Dynamo", has taken a position that P.Ms device was published before anyone else.
At the moment I don't have the complete text of this article to verify his references, but I would not automatically assume they are correct.
I would think the reason why this particular generator has not been included in mainstream history, is more to do with the gentlemans proclivity to anonymity rather than deliberate exclusion, after all Faraday was happy to get P.M. published.
I don't see any distortion in history regarding Faraday, he was not known to have produced a practical working generator either AC or commutated AC.
Perhaps you are just trying to create your own narrative about Faraday in your blog spot!
There were many that worked on generator designs after  Faraday published his paper.
L192
The fact that I see is a completed circuit of a multi-coil generator, which was given by unknown. The second fact is that there is already sufficient knowledge of electricity to propose such a device.
Practically the scheme of the simplest alternator, which is still relevant today.
https://youtu.be/p7e6Lu_YSCo
A generator/alternator/transformer/converter is calculated and built for a given average-continuous- value but included a short time peak value !
These are the two fixed values,before fuse or device destroying(isolation/cable,...) !
Physics to engineered device !
Holcombs concept does not wonder me !
In comparison to Harold Goldbaums electro-magnetic generator output claim !
A shoebox size (claimed) device with multiple MW output !
https://patents.google.com/patent/US8847720B2/en
Net Power Output after Feedback of 13.32 Kva The net output at 400 Hz is 16.871 Kva (22.6 Hp); at 800 Hz, 33.7 Kva (45.2 Hp); at 3 KHz=128 Kva (171.5 Hp); at 6 KHz=256 Kva (343 Hp); at 60 Khz=2.560 Kva; at 600 KHz=25.60 Kva; at 780 KHz=33.254 Kva.
Generator Rating Per Hour and Observations The cyclic output per second is multiplied by 3600 to indicate the generator's hourly rating. Thus, at 400 Hz=60.7 Kva/h; at 800 Hz=121.4 Kva/h; at 3 KHz=460.8 Kva/h; at 6 KHz=921.6 Kva/h; at 60 KHz=9.26 Mw/h; at 600 KLHz=92.166 Kw/h; at 780 KHz=119.7 Mw/h.
Where is Goldbaums :o device melting point,A/m !? Uncooled !?
Other view point : internal/external pressure/force from e-machine,non-/motive with
        1 KVA AC
                                         a.50 Hz / b.500 Hz / c.5000 Hz output /... ( probably with variable duty cycle )
        applied !
Induction heater ,as example ,charging !
wmbr
OCWL
rakarskiy
Ipolit Pixi (1808-1835) in the attachment is a drawing of his proposed generator, and the design of an unknown published in the magazine already ready for use. At the same time Pixi already has an element of transition to a generator with rectification. He may have been inspired by the unknown generator.
rakarskiy
Quote from: lancaIV on August 12, 2023, 12:56:06 PM
rakarskiy,
https://www.leifiphysik.de/elektrizitaetslehre/elektromagnetische-induktion/geschichte/pixii-generator
The only what I have in mind :Will Holcomb in the year 2210 also represented like Pixii 2023 ? ::)
wmbr
OCWL
The Pixie generator, the generator represented by the unknown, and the Holcomb generator all share the same principle of EMF guidance.
