listener192
I believe Faraday had made the correction in his lab notes (available on line) but it was too late to get this into his paper.
L192
rakarskiy
Quote from: listener192 on August 22, 2023, 01:34:45 PM
L192
I have a different approach to the law of electromagnetic induction and to the rule of Lenz clarifying this law. the law of electromagnetic induction must be looked at when you close the electrodes of the galvanic element, in the generator it is already a continuation. At the same time I do not insist, this is my version and concept without electrons in high-speed races.
https://rakatskiy-blogspot-com.translate.goog/p/emf-and-current-in-conductor.html?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
rakarskiy
Quote from: lancaIV on August 22, 2023, 03:02:56 PM
We can see the conservation laws a little more complex,included derivation :
https://www.google.com/url?q=https://arxiv.org/pdf/physics/0012009&sa=U&ved=2ahUKEwi7r4eV-PCAAxW4UKQEHcstB484KBAWegQIBhAC&usg=AOvVaw1wxQ9y1ncgyJa_KMT3G6Q7
The term "acyclic induction" overlaps with "non-contact" induction, or induction at the focus of a magnetic circuit, when the magnetic lines of force flux, envelope the conductor forming a closed magnetic flux without crossing the conductor.
E = (ϕ = ∆B*∆S)∆f,   where:  ϕ = ∆B*∆S, the resultant of the "inhomogeneous" parts of the ring-closed magnetic flux around the conductor.  Actually the resultant would be the ∆B value for the rotor and stator in a gap, magnetic circuit. (but I may be wrong on this question, as I do not have exact data yet). This phenomenon can be compared to the phenomenon of ANAPOL.
QuoteANAPOL (from Greek an - negative particle and polos - pole) (toroidal dipole) - a system of currents, the electromagnetic field of which is characterized by a vector of anapole momentum.
My post about an interesting experiment
This intersects with my theory of the electromagnetic flux structure of a conductor.
With this comparison, I concluded my post "The Invention of the Electromagnetic Generator"
https://en.m.wikipedia.org/wiki/Magnetic_circuit
Electrostatic non-/conventional closed circuit :
https://en.m.wikipedia.org/wiki/Electret
https://overunity.com/833/hilden-brand-magnet-motor/dlattach/attach/5493/image//
EE,circuits  : aktive and passive Bauelemente
Direct current or constant current  versus impulsive current  !
' Conservation of .....- laws on/off switch ~  charging on/off switch
Impulse electromagnetic anti-Helmholtz coils arrangement ( with-/out permanent magnet)
Impulse charge time /impulse work time(max. to min.) ~ impulse cycle decay : parametric generator
https://opg.optica.org/ol/abstract.cfm?uri=ol-47-5-1113
Caution :
https://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=2003079128&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
[0021]
Furthermore, in experiments conducted by the inventors, the permanent magnet 1 made of an alnico magnet and having a residual magnetic flux density of 8.45 kg was used for the long-time operation of the generator 6 of the present invention. Two U-shaped yokes 2 having a length of 25 cm are sandwiched and coordinated through a thin film paramagnetic body 20 made of an aluminum plate having a thickness of 0.03 mm. A magnetized coil 3 with a capacity of 6.2 kg is provided at the edge of the yoke 2. AC power of 24 V 2.6 W with a frequency of 1600 Hz is input to this magnetized coil 3, and power generation with an output of 32 V 3.1 W is continued for 240 hours. As a result of measuring the residual magnetic flux density of the permanent magnet 1, the reduction rate is 0.1% or less, and long-time operation is sufficiently possible.
power/weight ratio !
power/production costs ratio
wmbr
OCWL
