0 Members and 23 Guests are viewing this topic.
Ufopolitics
Hello to All,
Why is it that hard to distinguish the huge differences between AC versus DC Magnetic Fields in a Rotation?
AC keeps flashing currents between positive and negative at a rate of 60 or 50 cycles per second, which generates -IN THE SAME SPOT- Flashes of North-South @ 60Hz per Cycle. Hence there are absolutely no magnetic poles going anywhere, but flashing exactly in the same place.
Actually AC Currents keep resulting in zero in every frequency up-down, except it happens over a short period of time (60cycles/sec)
When several coils are positioned in a circular fashion, where they are aligned each others at 90, 120 or 180 degrees, and wound around circular steel cores and fed with AC, we get ALTERNATED N-S poles flashing -in place- at every coil...So, if we put a piece of steel within that circle, it rotates, NOT because there is a magnetic field "rotating" and the rotor is "following it", but because it is flashing constantly N-S Magnetic Poles across the center of steel stator, which generates alternated attract-repulse fields, which bolts down to "pull and push" forces across the circle, and placed 90º, 120º or 180º apart...or for a Three Phase it is a stepping action over time of three sequentially placed coils.
There are absolutely NO ROTATION THROUGH SPACE of the SAME North-South Poles in AC Currents.
A typical COMMUTATED DC Motor (PM or Universal, NOT BLDC) works thanks to a STATIONARY, IN PLACE, AND NOT VARYING Magnetic Field, and what makes it "rotate" are the constant Coils reversing polarities at every step of commutator, while Magnetic Field is STATIC within the whole motor embodiment, including the Stator.
Brushless DC Motors (BLDC) runs thanks to a Three Phase DC SQUARE WAVE, spread at 120º apart (except for PC Fans and other small motors, which work with just one phase DC with Hall Sensors) This 3Phase DC generates a FLASHING STEPPING FIELD, similar to AC, except they have a full positive,  FLAT LINE alternating between Positive and Negative...above and below.
NONE of ALL Motors mentioned above, Not ANY Transformer, have a FULLY ROTATIONAL MAGNETIC FIELD, MUCH LESS, DC MOTORS.
*Developments on Figuera, Cotnoir and Holcomb did or are doing, is Moving THROUGH SPACE, a Constant, not flashing, not changing over time, NEVER COLLAPSING TO ZERO, Magnetic Field...and that, can only be achieved with a constant one Directional Current...called DC.
Exactly as Generators Rotors-Exciter, Inducing Fields do...except they rotate physically the Magnetic Field, by rotating the whole thing who carries it, namely the Steel Core and Coils...
What has taken place with above developments* is a CONSTANT, FULL MOVEMENTS or ROTATIONS of JUST the VIRTUAL Magnetic Field, without involving physical rotation of Steel Cores nor Coils.
Huge difference People...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on April 05, 2022, 09:29:39 AM
Hello to All,
Ufopolitics
Ufo,
You are wrong. The Alternating Currents produce mmf's which vary in amplitude over time in locations around the circular air gap. All these mmf's are a "field" in themselves which is, or gives rise, to the flux field, which is the sum of all the point mmf's at each instant. This "sum" or combination is in fact a non alternating constant magnitude flux which travels with respect to time around the air gap. A stationary charge, or test probe, in the air gap would detect absolutely no difference between the rotating magnetic field produced by the 3-phase stator and that from a rotating wound field or PM rotor.
It is not intuitive, but I've seen the mathematical proof as well as experimental demonstration. I realize that you do not believe this is possible, however it is the truth. Every engineering textbook that I can recall covers this at the beginning of the chapters on AC motors and generators. It helped to have the professor cover it in the lecture/classroom.
bi
pmgr
@Bistander,
You are correct. I have done extensive modeling of EM fields in various areas and it makes no difference by what source a field is excited (DC or AC). I also note that Holcomb mentions that his DC exciting coils can be replaced or supplemented by an AC 3 phase rotor (he actually mentions the use of a 3 phase motor stator in one of the patens to create/supplement the moving field).
The fact that this device is over-unity is because Lenz is being circumvented/manipulated! None of this electron-spin stuff.
Ufopolitics
Quote from: bistander on April 05, 2022, 11:48:55 AM
... A stationary charge, or test probe, in the air gap would detect absolutely no difference between the rotating magnetic field produced by the 3-phase stator and that from a rotating wound field or PM rotor.
bi
Bistander,
If it makes no difference a 3 phase stator and a Permanent Magnetic Field then why, going through the trouble to insert Diodes in every Rotating Inducing Field in a Generator?...may as well get an AC wound Rotor, without Diodes, and it should do exactly same thing, with AC Inducing Fields...
Could You explain why it is not done with AC?
Also, we could just get a three Phase Stator, feed it with 3 Phase currents, and set in the center a Stationary Secondary Field, wound 3 Phase Coils...but then all we have is a 3 Phase Transformer right?...
Cheers
Ufopolitics
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on April 05, 2022, 12:49:45 PM
Bistander,
Cheers
Ufopolitics
It is done that way in 3-phase induction motor and generators.
Last question.... Yes. That is what I, and a few others, have been telling you. We've been doing it since Tesla, you just didn't realize it.
bi
