0 Members and 25 Guests are viewing this topic.
Feb2006
Alternating between four input spikes (1N 1S)(2N 2S)(3N 3S)(4N 4S).
Feb2006
It's a big delay between input spikes for now. What do you think will happens when
we make it faster?
//initialize
digitalWrite(out01, HIGH);
digitalWrite(out02, HIGH);
digitalWrite(out03, HIGH);
digitalWrite(out04, LOW);
int tmicrsec = 1000;     // delay microsecond
while (1)
  digitalWriteFast(out01, LOW);   // turn the out01 off
  digitalWriteFast(out04, HIGH);  // turn the out04 on
delayMicroseconds(tmicrsec);     // wait
  digitalWriteFast(out02, LOW);   // turn the out02 off
  digitalWriteFast(out01, HIGH);  // turn the out01 on
  digitalWriteFast(out03, LOW);   // turn the out03 off
  digitalWriteFast(out02, HIGH);  // turn the out02 on
  digitalWriteFast(out04, LOW);   // turn the out04 off
  digitalWriteFast(out03, HIGH);  // turn the out03 on
kolbacict
I don't understand nothing. About what device goes to say ? circuit ?
Feb2006
solid state linear generator  LINGEN
8 input coils 32 turns on each, 4 north 4 south (1N 2N 3N 4N)(1S 2S 3S 4S)
out01..04 goes to 1 north and 1 south input coil each.
And turns on or off with 4 mosfets.
8 output coils in series 12 turns on each and a 33 ohm resistor series connected.
SolarLab
Quote from: Feb2006 on September 17, 2023, 01:03:43 PM
Hi Feb2006,
Some excellent work!
FYI - included two B-H Curve data sheets for the TDK Ferrite Cores I think you are using.
(from your previous pdf - you likely have these already, but in case not)
The complete data sheets and some other good design data are here:
https://www.tdk-electronics.tdk.com/download/519704/069c210d0363d7b4682d9ff22c2ba503/ferrites-and-accessories-db-130501.pdf
Thanks for sharing! [* likely the first OU device to be shared on the forums *] Also, thanks for the code...
Best Regards,
SL
