kolbacict
And i am doing this.
I was given a tentative option for connecting the coils.
What can you say?
forest
connection has to be such as to fulfill arragement which give you zero lenz law effect while maximize EMF output
rakarskiy
You are moving away from a topic that is much more interesting than Andrea Slobodian rotator rotator.
In 1902, Clemente Figuera introduced a converter in cosmic efficiency. His device received energy at the input from a small dynamo, with an alternating current output. The energy entered the device and had an output from the device, with a much higher power indicator. It was only in 1908 that a resistive switch was proposed to control and receive energy from a DC source.
The main thing is the concept that has been defined, not transformer but trans generator.
I am even more sure that Tesla's mechanical converter (late 19th century) had the same principle. A 90-degree shift should be sought not in the waveform graph, but in the mechanical placement of the structure.
I am giving a link to a Canadian patent: Electrical generator - solid state configuration
https://patentimages.storage.googleapis.com/f1/73/db/bddc31a19a8100/CA2357550A1.pdf
https://patents.google.com/patent/CA2357550A1/en
Quote1. An electrical generator which has no moving parts.
2. An electrical generator with no moving parts which has no apparent size or output limitations.
3. An electrical generator which operates with all of its essential components, including electromagnets and coils, in stationary position.
4. A solid state electrical generator.
5. A solid state electrical generator which can provide its energy or electrical current output as either alternating current, or direct current.
6. An electrical generator which requires no mechanical motive power for its operation or output.
7. An electrical generator which can be built in a more compact form, for the amount of its potential output than would be the case with mechanically powered and operated electrical generators.
8. An electrical generator which can be miniaturized to very small proportions, to where it may be used as a small portable or emergency energy source, in either AC or DC, to power electronic, radio or telecommunications installations, etc.
9. An electrical generator which, when energized by an available DC power source, can operate for the long term, to the extent of the lifespan of one or more of its essential components.
I think if you have a brain, you don't need commentaries.
This is still the same concept of an electromagnetic converter according to the trans generator principle.
kolbacict
Quote from: rakarskiy on May 01, 2022, 03:09:42 AM
This switch with resistors is simply a circular rheostat with a running contact along the wire.
In any case, a round rheostat without a limiter would produce a smoother change in resistance.
Why didn't Figuera use it?
з.ы.
How can I get to Ukraine now?
Only through third countries? ;)
rakarskiy
https://patentimages.storage.googleapis.com/c0/74/57/63c418177a51dc/US20020125774A1.pdf
Аnother similar design!
It has inaccuracies where direct repetition makes it meaningless.
In the left figure, the location of the excitation electromagnets indicated in the patent (absurd from the point of view of working with the phase winding of the output current), in the right figure, my edits how to do it right.
