0 Members and 18 Guests are viewing this topic.
bistander
Quote from: rakarskiy on May 01, 2022, 02:58:24 PM
https://patentimages.storage.googleapis.com/c0/74/57/63c418177a51dc/US20020125774A1.pdf
Аnother similar design!
It has inaccuracies where direct repetition makes it meaningless.
In the left figure, the location of the excitation electromagnets indicated in the patent (absurd from the point of view of working with the phase winding of the output current), in the right figure, my edits how to do it right.
Hello rakarskiy,
I think you miss the fact it is for 3-phase, 2-pole as shown in his Fig. 6.
bi
Ufopolitics
I also have been working on this systems for a very  long time...
Figuera did NOT get his input from "any dynamo"...but from a simple Battery...
Figuera used a Commutator driven by a very small motor (that he got built for him in Germany) and the effect he created was to MOVE the VIRTUAL MAGNETIC FIELD back and forth in the Exciting Coils, in a sequential way in order to Induce all his Output Coils in front and rear of the exciters.
I have also reproduced Figuera, plus I have read his Patent from the original Language it was written (Spanish)...There are a lot of bad translations going around...
This is NOT about any Transformer or Trans Generator kind of deal...
This is simply moving a VIRTUAL MAGNETIC FIELD through Steel Cores and Copper Coils...
And there are MANY WAYS to attempt to build this...However, to be "successful" is NOT guaranteed... ;D
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
onepower
Ufopolitics
QuoteI also have been working on this systems for a very  long time...
Initially I thought so as well however from the 1908 patent after Figuera describes his rotary switch ...
QuoteFrom this current is derived a small part to excite the machine
converting it in self-exciting and to operate the small motor which moves the
brush and the switch; the external current supply, this is the feeding current,
is removed and the machine continue working without any help indefinitely
Here he seems to claim he removes the feeding current, the battery, and the machine becomes self-exciting. I believe I caught this around 2016 and didn't know what to think initially. My theory at the time was that the independently induced coils "y" may feed energy back into the system or the switched german silver resistance coils "R" play some part.
It's definitely an enigma and I learn something new every time I reread a patent, more so after a period of time. I takes time for an idea to properly form in our mind.
I also look at the "keywords" used throughout a patent to describe a component or feature. Here Figuera talks about self-excitation, working without any help indefinitely, no new force is required and the machine will continue in operation indefinitely. I could be wrong but my intuition tells me this is a self-runner and does not need an input source to operate.
Of course today were not allowed to use such language or a patent is labelled a perpetua mobilia. I found all the patents prior to 1940 are where all the best descriptions of working technology are found. All this new age bs never did start my tractor, lol.
AC
rakarskiy
Friends, I came to my transformer (on the principle of a transgenerator) myself, several years ago. Only then did I start looking for similar technologies and found them with Clemente Figuer (possibly Tesla), a French patent, and all other devices change only in name and engineering design, but the principle is common to all. I'm not entirely public on the resonant circuit system and this transgeneration technology. There are also my mechanical developments on a similar principle "Rotoverter RAGEN". In the near future I will finish my material, I want it to be with a calculation algorithm. By the way, I worked out the principle of transgeneration (for a removable transformer) in order to remove power from the resonant circuit, but when everything came together in the calculated data, I was convinced of my mistake. But for the electromagnetic principle, this method is the best.
In the figure, where I show an error in a continuous Electric Generator, this is fundamental, if you have not seen, then you do not understand how the phase of the secondary circuit should work.
There are no secrets, everything is in physics textbooks, and these designs are engineering art.
Attached is the Portnov generator, a similar principle for understanding.
onepower
Rakarskiy
Indeed it is an art...
Many would suppose these electrical devices are life less like paint and anyone can throw them together. However only a true artist can turn ordinary paint into a masterpiece. The paint has little to do with it and it was the creativity, vision and application which produced the end result.
Sure some could be taught to paint by numbers but we should never confuse what a real artist does. An artist takes something ordinary and turns it into something unique greater than the simple sum of its parts.
AC
